Author Topic: SPS2306 vintage transistor replacement  (Read 1226 times)
Offline gkmaiaTopic starter
  • Electronics Hobbyist
« on: April 19, 2020, 11:02:15 pm »
I am struggling hard to find a data sheet for a SPS2306 (M176) NPN signal transistor.
Closest reference cross I found was this one.
https://vetco.net/products/2n3904-bc547-pn2222-2n4401-npn-transistor-nte123ap
It is for Q11/12 on the schematics bellow.
Offline vk6zgo
Re: SPS2306 vintage transistor replacement
« Reply #1 on: April 20, 2020, 12:11:41 am »
I have found equivalents lists of little use, & fall back on other means.
An old trick is to check whether the equipment uses the same device elsewhere in a "non critical" role.
If so, you can probably steal that one & get a "jelly bean" device for the "donor" spot.
Another idea is to have a look around to find out what device other manufacturers use in a similar position.
The old "What does Philips/Sony/whoever do?" trick.
Offline duak
« Reply #2 on: April 20, 2020, 03:25:09 am »
I see that Q11/Q12 are used as back to back zener diodes to clamp the voltage to +/-7 V or so.  I have seen the 2N4401 used for this purpose more than any other device but I can't say why; maybe because it is rated for 600 mA.
Here's a link to National Semi's 1971 transistor data book.  It's surprising how many devices with different numbers use the same die.
Offline Benta
« Reply #3 on: April 20, 2020, 10:36:23 am »
SPS transistor numbers were very often custom stamped Motorola types back then. Could be almost anything, you'll need to find an old Motorola Small Signal databook.
« Reply #4 on: April 20, 2020, 11:10:56 am »
thanks for the old databook tip. I think I found it.
Offline critchy87
« Reply #5 on: December 05, 2024, 07:10:18 pm »
Hi I’m actually looking to replace same transistor sps2306 on a b&k 467 pcb. Did you ever find an equivalent or something that will work?
Thanks
William
