Author Topic: Star and Delta motor field winding configurations are not efficient.  (Read 1173 times)
Offline Peter TaylorTopic starter
    • Pete's Electronic Workshop
The three field windings displaced by 1/3 of a revolution of an electronic motor can be configured in the following three ways.
Star (where an end of each winding is connected in common and the other three make four external connections).
This requires that one winding be off in each revolution, giving a power to weight ratio of 2/3 of the maximum.
Delta (where the three windings are connected in series and the junctions give three external connections).
Other (where the ends of each winding make six external connections).
This allows three windings to be on at all times, giving a maximum power to weight ratio.
The common consensus in electronic motor control is to use Star or Delta configurations.
The third configuration has a 1/3 higher power to weight ratio.
This article explains why this rarely appears in a google search for 'electronic motor control'.
It is cheaper on a commercial scale to manufacture Star and Delta configurations because they require fewer half h bridges and external copper connections.
The Other configuration requires three full h bridges and six external copper wire connections, and costs more.
In reality, the most efficient design has been hidden by a ruling class who's motivation is greed, not elegance (beauty and simplicity in design).
« Last Edit: June 13, 2022, 01:59:42 pm by Peter Taylor »
Offline rob77
  • Country: sk
Re: Star and Delta motor field winding configurations are not efficient.
« Reply #1 on: June 13, 2022, 02:10:36 pm »
what the actual f**k are you talking about ?  :-// in a 3phase system you never have a "winding OFF" , you have 3 phases 120degrees apart and none of them if "OFF" in any point in time.
Offline Brumby
« Reply #2 on: June 13, 2022, 02:16:35 pm »
Fascinating.
Please show your working.
« Reply #3 on: June 13, 2022, 02:27:49 pm »
The article mentions a h bridge. Does this imply a switched controller, or a linear one ?
I am not teaching basic theory. You show the reasoning.
« Last Edit: June 13, 2022, 02:33:11 pm by Peter Taylor »
Offline Brumby
« Reply #4 on: June 13, 2022, 02:51:48 pm »
The article ...
What article?
... mentions a h bridge. Does this imply a switched controller, or a linear one ?
H bridge topology is not hard to understand.  Try Google.
That's "Trolling 101".  Come back when you understand some basics about H bridges, 3 phase and how they relate to motor operation.
Oh ... and don't forget the elephant in the room: Physical construction and all that that entails.
« Reply #5 on: June 13, 2022, 03:15:51 pm »
I don't come here to ask questions, but to make statements.
An article is a statement.
« Last Edit: June 13, 2022, 03:18:05 pm by Peter Taylor »
Offline Siwastaja
« Reply #6 on: June 13, 2022, 03:27:59 pm »
Nothing you wrote made any sense, to the point it's not even correctable. Maybe try do a literature research how an AC motor works and try again.
Offline wraper
  • Country: lv
« Reply #7 on: June 13, 2022, 04:01:33 pm »
And of course no article was shown  :palm:
Offline wraper
  • Country: lv
« Reply #8 on: June 13, 2022, 04:03:50 pm »
In reality, the most efficient design has been hidden by a ruling class who's motivation is greed.
The most common claim when you try to sell some BS.
Offline BrokenYugo
« Reply #9 on: June 13, 2022, 04:36:47 pm »
Yes, and I have a secret carburetor that will give 100 mpg installed in a full size 1970s Detroit built V8 car.
Offline Gregg
« Reply #10 on: June 13, 2022, 04:42:42 pm »
This troll attempt belongs in the Dodgy Tech section as a neighbor with the nonlinear plasma troll.  :bullshit:
At least nonlinear plasma makes a feeble attempt to justify his outrageous claims.
The following users thanked this post: Cyberdragon
Online Benta
« Reply #11 on: June 13, 2022, 04:50:27 pm »
Hahaha! Great entertainment!  :-DD
The following users thanked this post: Omega Glory
Online andy3055
« Reply #12 on: June 13, 2022, 05:08:35 pm »
"... not teaching basic theory "
One must first understand basic theory to make "statements" ... which is your own declaration! Why do you come to a public forum like this where there are learned people and try to convince them and still argue to make a fool of yourself?
Offline eugene
« Reply #13 on: June 13, 2022, 05:38:13 pm »
The OP has confused simple methods of driving BLDC motors with 3 phase AC motors. That, in itself, is neither crime nor sin. The hang is that he is unwilling to learn but insists on "teaching."
OP, your only contribution to EEVBlog is starting three bullshit threads. You need to close your mouth and just listen. Not everything that pops into your head should be shared on a public forum.
90% of quoted statistics are fictional
The following users thanked this post: ebastler, tooki
