Author Topic: Possible bug in MPASM include "16f627.inc" (and other include files)  (Read 6551 times)
Offline glossywhiteTopic starter
Hi there. I have been scanning through some code that was included in my Velleman PIC programmer, and in the ASM listing to disable data code protection, it explicitly says "_DATA_CP_OFF", whereas in the Microchip MPASM include file "16f627.inc" you will see the preceeding underscore "_" missing, and it simply says "DATA_CP_OFF". This is also the case in other .INC files in the latest MPASM.
Here is the listing for the latest "16f627.inc" so you can see for yourself. Surely this is an error?:
        LIST
;  MPASM PIC16F627 processor include
;  (c) Copyright 1999-2010 Microchip Technology, All rights reserved
        NOLIST
;  This header file defines configurations, registers, and other useful
;  bits of information for the PIC16F627 microcontroller.  These names
;  are taken to match the data sheets as closely as possible.
;  Note that the processor must be selected before this file is included.
;  The processor may be selected the following ways:
;       1. Command line switch:
;               C:\MPASM MYFILE.ASM /PIC16F627
;       2. LIST directive in the source file
;               LIST   P=PIC16F627
;       3. Processor Type entry in the MPASM full-screen interface
;       4. Setting the processor in the MPLAB Project Dialog
;       Verify Processor
        IFNDEF __16F627
           MESSG "Processor-header file mismatch.  Verify selected processor."
        ENDIF
;       Register Definitions
W                EQU  H'0000'
F                EQU  H'0001'
;----- Register Files -----------------------------------------------------
;-----Bank0------------------
INDF             EQU  H'0000'
TMR0             EQU  H'0001'
PCL              EQU  H'0002'
STATUS           EQU  H'0003'
FSR              EQU  H'0004'
PORTA            EQU  H'0005'
PORTB            EQU  H'0006'
PCLATH           EQU  H'000A'
INTCON           EQU  H'000B'
PIR1             EQU  H'000C'
TMR1L            EQU  H'000E'
TMR1H            EQU  H'000F'
T1CON            EQU  H'0010'
TMR2             EQU  H'0011'
T2CON            EQU  H'0012'
CCPR1            EQU  H'0015'
CCPR1L           EQU  H'0015'
CCPR1H           EQU  H'0016'
CCP1CON          EQU  H'0017'
RCSTA            EQU  H'0018'
TXREG            EQU  H'0019'
RCREG            EQU  H'001A'
CMCON            EQU  H'001F'
;-----Bank1------------------
OPTION_REG       EQU  H'0081'
TRISA            EQU  H'0085'
TRISB            EQU  H'0086'
PIE1             EQU  H'008C'
PCON             EQU  H'008E'
PR2              EQU  H'0092'
TXSTA            EQU  H'0098'
SPBRG            EQU  H'0099'
EEDATA           EQU  H'009A'
EEADR            EQU  H'009B'
EECON1           EQU  H'009C'
EECON2           EQU  H'009D'
VRCON            EQU  H'009F'
;----- STATUS Bits -----------------------------------------------------
C                EQU  H'0000'
DC               EQU  H'0001'
Z                EQU  H'0002'
NOT_PD           EQU  H'0003'
NOT_TO           EQU  H'0004'
IRP              EQU  H'0007'
RP0              EQU  H'0005'
RP1              EQU  H'0006'
;----- PORTA Bits -----------------------------------------------------
RA0              EQU  H'0000'
RA1              EQU  H'0001'
RA2              EQU  H'0002'
RA3              EQU  H'0003'
RA4              EQU  H'0004'
RA5              EQU  H'0005'
RA6              EQU  H'0006'
RA7              EQU  H'0007'
;----- PORTB Bits -----------------------------------------------------
RB0              EQU  H'0000'
RB1              EQU  H'0001'
RB2              EQU  H'0002'
RB3              EQU  H'0003'
RB4              EQU  H'0004'
RB5              EQU  H'0005'
RB6              EQU  H'0006'
RB7              EQU  H'0007'
;----- INTCON Bits -----------------------------------------------------
RBIF             EQU  H'0000'
INTF             EQU  H'0001'
T0IF             EQU  H'0002'
RBIE             EQU  H'0003'
INTE             EQU  H'0004'
T0IE             EQU  H'0005'
PEIE             EQU  H'0006'
GIE              EQU  H'0007'
TMR0IF           EQU  H'0002'
TMR0IE           EQU  H'0005'
;----- PIR1 Bits -----------------------------------------------------
TMR1IF           EQU  H'0000'
TMR2IF           EQU  H'0001'
CCP1IF           EQU  H'0002'
TXIF             EQU  H'0004'
RCIF             EQU  H'0005'
CMIF             EQU  H'0006'
EEIF             EQU  H'0007'
;----- T1CON Bits -----------------------------------------------------
TMR1ON           EQU  H'0000'
TMR1CS           EQU  H'0001'
NOT_T1SYNC       EQU  H'0002'
T1OSCEN          EQU  H'0003'
T1CKPS0          EQU  H'0004'
T1CKPS1          EQU  H'0005'
;----- T2CON Bits -----------------------------------------------------
TMR2ON           EQU  H'0002'
T2CKPS0          EQU  H'0000'
T2CKPS1          EQU  H'0001'
TOUTPS0          EQU  H'0003'
TOUTPS1          EQU  H'0004'
TOUTPS2          EQU  H'0005'
TOUTPS3          EQU  H'0006'
;----- CCP1CON Bits -----------------------------------------------------
CCP1Y            EQU  H'0004'
CCP1X            EQU  H'0005'
CCP1M0           EQU  H'0000'
CCP1M1           EQU  H'0001'
CCP1M2           EQU  H'0002'
CCP1M3           EQU  H'0003'
;----- RCSTA Bits -----------------------------------------------------
RX9D             EQU  H'0000'
OERR             EQU  H'0001'
FERR             EQU  H'0002'
ADEN             EQU  H'0003'
CREN             EQU  H'0004'
SREN             EQU  H'0005'
RX9              EQU  H'0006'
SPEN             EQU  H'0007'
ADDEN            EQU  H'0003'
;----- CMCON Bits -----------------------------------------------------
CIS              EQU  H'0003'
C1INV            EQU  H'0004'
C2INV            EQU  H'0005'
C1OUT            EQU  H'0006'
C2OUT            EQU  H'0007'
CM0              EQU  H'0000'
CM1              EQU  H'0001'
CM2              EQU  H'0002'
;----- OPTION_REG Bits -----------------------------------------------------
PSA              EQU  H'0003'
T0SE             EQU  H'0004'
T0CS             EQU  H'0005'
INTEDG           EQU  H'0006'
NOT_RBPU         EQU  H'0007'
PS0              EQU  H'0000'
PS1              EQU  H'0001'
PS2              EQU  H'0002'
;----- TRISA Bits -----------------------------------------------------
TRISA0           EQU  H'0000'
TRISA1           EQU  H'0001'
TRISA2           EQU  H'0002'
TRISA3           EQU  H'0003'
TRISA4           EQU  H'0004'
TRISA5           EQU  H'0005'
TRISA6           EQU  H'0006'
TRISA7           EQU  H'0007'
;----- TRISB Bits -----------------------------------------------------
TRISB0           EQU  H'0000'
TRISB1           EQU  H'0001'
TRISB2           EQU  H'0002'
TRISB3           EQU  H'0003'
TRISB4           EQU  H'0004'
TRISB5           EQU  H'0005'
TRISB6           EQU  H'0006'
TRISB7           EQU  H'0007'
;----- PIE1 Bits -----------------------------------------------------
TMR1IE           EQU  H'0000'
TMR2IE           EQU  H'0001'
CCP1IE           EQU  H'0002'
TXIE             EQU  H'0004'
RCIE             EQU  H'0005'
CMIE             EQU  H'0006'
EEIE             EQU  H'0007'
;----- PCON Bits -----------------------------------------------------
NOT_BOR          EQU  H'0000'
NOT_POR          EQU  H'0001'
OSCF             EQU  H'0003'
NOT_BO           EQU  H'0000'
NOT_BOD          EQU  H'0000'
;----- TXSTA Bits -----------------------------------------------------
TX9D             EQU  H'0000'
TRMT             EQU  H'0001'
BRGH             EQU  H'0002'
SYNC             EQU  H'0004'
TXEN             EQU  H'0005'
TX9              EQU  H'0006'
CSRC             EQU  H'0007'
;----- EECON1 Bits -----------------------------------------------------
RD               EQU  H'0000'
WR               EQU  H'0001'
WREN             EQU  H'0002'
WRERR            EQU  H'0003'
;----- VRCON Bits -----------------------------------------------------
VRR              EQU  H'0005'
VROE             EQU  H'0006'
VREN             EQU  H'0007'
VR0              EQU  H'0000'
VR1              EQU  H'0001'
VR2              EQU  H'0002'
VR3              EQU  H'0003'
;       RAM Definitions
       __MAXRAM  H'01FF'
       __BADRAM  H'0007'-H'0009'
       __BADRAM  H'000D'
       __BADRAM  H'0013'-H'0014'
       __BADRAM  H'001B'-H'001E'
       __BADRAM  H'0087'-H'0089'
       __BADRAM  H'008D'
       __BADRAM  H'008F'-H'0091'
       __BADRAM  H'0093'-H'0097'
       __BADRAM  H'009E'
       __BADRAM  H'0105'
       __BADRAM  H'0107'-H'0109'
       __BADRAM  H'010C'-H'011F'
       __BADRAM  H'0150'-H'016F'
       __BADRAM  H'0185'
       __BADRAM  H'0187'-H'0189'
       __BADRAM  H'018C'-H'019F'
       __BADRAM  H'01A0'-H'01EF'
;       Configuration Bits
;   NAME            Address
;   CONFIG            2007h
; The following is an assignment of address values for all of the
; configuration registers for the purpose of table reads
_CONFIG          EQU  H'2007'
;----- CONFIG Options --------------------------------------------------
_LP_OSC              EQU  H'3FEC'    ; LP oscillator: Low-power crystal on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_XT_OSC              EQU  H'3FED'    ; XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_HS_OSC              EQU  H'3FEE'    ; HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
_EXTCLK_OSC          EQU  H'3FEF'    ; EC: I/O function on RA6/OSC2/CLKOUT pin, CLKIN on RA7/OSC1/CLKIN
_INTRC_OSC_NOCLKOUT  EQU  H'3FFC'    ; INTRC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_INTRC_OSC_CLKOUT    EQU  H'3FFD'    ; INTRC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
_ER_OSC_NOCLKOUT     EQU  H'3FFE'    ; ER oscillator: I/O function on RA6/OSC2/CLKOUT pin, Resistor on RA7/OSC1/CLKIN
_ER_OSC_CLKOUT       EQU  H'3FFF'    ; ER oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, Resistor on RA7/OSC1/CLKIN
_WDT_OFF             EQU  H'3FFB'    ; WDT disabled
_WDT_ON              EQU  H'3FFF'    ; WDT enabled
_PWRTE_ON            EQU  H'3FF7'    ; PWRT enabled
_PWRTE_OFF           EQU  H'3FFF'    ; PWRT disabled
_MCLRE_OFF           EQU  H'3FDF'    ; RA5/MCLR pin function is digital input, MCLR internally tied to VDD
_MCLRE_ON            EQU  H'3FFF'    ; RA5/MCLR pin function is MCLR
_BODEN_OFF           EQU  H'3FBF'    ; BOD Reset disabled
_BODEN_ON            EQU  H'3FFF'    ; BOD Reset enabled
_LVP_OFF             EQU  H'3F7F'    ; RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming
_LVP_ON              EQU  H'3FFF'    ; RB4/PGM pin has PGM function, low-voltage programming enabled
DATA_CP_ON           EQU  H'3EFF'    ; Data memory code protected
DATA_CP_OFF          EQU  H'3FFF'    ; Data memory code protection off
_CP_ALL              EQU  H'03FF'    ; 0000h-03FFh code protected
_CP_75               EQU  H'17FF'    ; 0200h-03FFh code protected
_CP_50               EQU  H'2BFF'    ; Program memory code protection off
_CP_OFF              EQU  H'3FFF'    ; Program memory code protection off
;----- DEVID Equates --------------------------------------------------
_DEVID1          EQU  H'2006'
;----- IDLOC Equates --------------------------------------------------
_IDLOC0          EQU  H'2000'
_IDLOC1          EQU  H'2001'
_IDLOC2          EQU  H'2002'
_IDLOC3          EQU  H'2003'
        LIST
« Last Edit: February 01, 2011, 12:46:18 pm by glossywhite »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Possible bug in MPASM include "16f627.inc" (and other include files)
« Reply #1 on: February 01, 2011, 02:55:25 pm »
thats not a bug, thats ladybird.
« Last Edit: February 01, 2011, 02:59:27 pm by Mechatrommer »
« Reply #2 on: February 01, 2011, 03:04:30 pm »
 ::) ...  :D
Offline Balaur
« Reply #3 on: February 01, 2011, 04:09:36 pm »
That's strange.
I've checked the include files from PicProg2009 (the tool that Velleman provides as a free download for the K8048). This tool actually includes an somewhat older version (v5.2) of the Microchip MPASM tool.
Thus, the include files are identical to the files provided with MPASM (v5.37) from my installation of the MPLAB v8.56 and work as expected.
Here is an excerpt:
        LIST
; P16F627.INC  Standard Header File, Version 1.01    Microchip Technology, Inc.
        NOLIST
; This header file defines configurations, registers, and other useful bits of
; information for the PIC16F627 microcontroller.  These names are taken to match
; the data sheets as closely as possible.
; included.  The processor may be selected the following ways:
;               C:\ MPASM MYFILE.ASM /PIC16F627
;               LIST   P=PIC16F627
;       Revision History
;Rev:   Date:    Reason:
;1.01   13 Sept 2001   Added _DATA_CP_ON and _DATA_CP_OFF
;1.00   10 Feb 1999 Initial Release
_CP_ALL                      EQU     H'03FF'
_CP_75                       EQU     H'17FF'
_CP_50                       EQU     H'2BFF'
_CP_OFF                      EQU     H'3FFF'
_DATA_CP_ON                  EQU     H'3EFF'
_DATA_CP_OFF                 EQU     H'3FFF'
_WDT_ON                      EQU     H'3FFF'
_LVP_ON                      EQU     H'3FFF'
_LP_OSC                      EQU     H'3FEC'
_XT_OSC                      EQU     H'3FED'
_HS_OSC                      EQU     H'3FEE'
        LIST
What is your MPLAB version?
Maybe they changed some stuff in the MPLAB X?
Cheers,
Dan
« Reply #4 on: February 01, 2011, 04:17:06 pm »
I have MPLAB v8.63 and MPASM v5.39. It seems your versions are out of date, but I still cannot work out why this is how it is... odd.
  • Country: my
« Reply #5 on: February 01, 2011, 04:26:23 pm »
its just a definition, you can name whatever definition you like, assuming the value is the same. as long as it is compiled, you are ok.
« Last Edit: February 01, 2011, 04:29:23 pm by Mechatrommer »
« Reply #6 on: February 01, 2011, 04:43:28 pm »
Yes, I know, but that doesn't escape the fact that the syntax is still incorrect. In ASM, each fuse begins with an "_" underscore, and the __CONFIG, a *double* "__" underscore. I know it will work, but that was not my point.
Offline Balaur
« Reply #7 on: February 01, 2011, 04:44:23 pm »
This change may break your own code if the configuration word (__CONFIG) relies on pre-defined options. Ex:
	processor	16f627
include <p16f627.inc>
__CONFIG        _CP_OFF & _WDT_OFF & _PWRTE_ON & _EXTCLK_OSC & _BODEN_ON & _LVP_OFF
  • Country: my
« Reply #8 on: February 01, 2011, 05:01:28 pm »
and again, thats not called syntax, thats called coding style.
yes, if you run old codes in a new library vice versa. that "coding style" is changing which is not a very good thing for the programmer/library maker who code it, ie Microchip, in your case.
you may as well call the "coding style" as "backward compatibilitiness".
although, there maybe a reason for the change which i dont know, finding it out might give some clue.
and possibly its a bug, but i seldomly saw this kind of stupid bug, reporting to Microchip might give some clue... as well.
« Last Edit: February 01, 2011, 05:23:00 pm by Mechatrommer »
« Reply #9 on: February 01, 2011, 05:46:56 pm »
...and again, thats not called syntax, thats called coding style.
I actually beg to differ, Shafri. I think this is actually syntax, because the prefixed "_" underscore is always used within the context of assembly for PIC.
PS: Not that it makes one iota of difference to me, but why have you changed your username? :)
Offline RayJones
    • Personal Website
« Reply #10 on: February 01, 2011, 06:45:15 pm »
The use of a leading underscore is a standard across many compilers, if not actually chiseled into stone.
The C source would be without the underscore, the *generated* assembly will have a leading underscore.
The same rule applies if you wanted to write an assembly function called from the C source file.
In asm, you have to create the function name with the underscore, but in C you leave it out.
The linker however sees the generated C name has a underscore, and thus matches perfectly with the asm file (which of course is not compiled, but assembled)
Welcome to the world of including ASM code with C code!
