I replaced a faulty (worn) timer-switch in house today, and noticed that-- by simply connecting one side of my Sears multimeter onto the hot supply wire, I would actually see ~30 volts (meter set to A/C 200,) even before I had a chance to touch the other side to neutral or ground... Could someone explain this phenomena to me? In detail, I hope not just "yeah it's the inductance in the line" or something like that, but really tell me how the multimeter measures voltage in the first place and how the electrons are moving around. Of course you could tell me that my REAL problem was holding on to the bare-wire exposed on my multimeter probes, and the tub of salty water I was standing in....
Related to this is-- how do "voltage ticks" work? Those things pen-like devices that light up when you approach a 'hot' wire. These baby's light-up even when there's no load or current passing through the wire.
But the biggest question is-- could this be a fault of my not-so-cheap-at-the-time made in Korea multimeter, and would having a fancy-dancy Fluke solve this problem? I see that Fluke also makes their version of a voltage-tick... Better than the $20 GB Electrical unit that I have?
Thanks in advance,
-Trent
