Author Topic: Static electricity from vacuuming up spilled kitty litter  (Read 7835 times)
Offline james_sTopic starter
« on: February 25, 2018, 10:58:46 pm »
I've observed an interesting phenomenon recently that I've been meaning to bring up. I have one of those Dyson cordless vacuum cleaners and I've found that when I vacuum up spilled clay kitty litter it generates a tremendous amount of static electricity. It's enough to cause a small lightning bolt to shoot out of the charging jack every few seconds, discharging painfully to my palm. If I hold my hand away from that area it will discharge even further from around the trigger to my finger, it's like a Van de Graaff generator. I noticed this same effect with the identical vacuum my mom has but I've not yet found anything other than kitty litter that causes it to happen. Does anyone know why litter in particular does this? Clay is not a material I typically associate with static electricity.
Offline Mr. Scram
  • Display aficionado
Re: Static electricity from vacuuming up spilled kitty litter
« Reply #1 on: February 25, 2018, 11:19:14 pm »
That sounds like the triboelectric effect to me. Which combinations of materials charge effectively can be fairly unpredictable.
https://en.wikipedia.org/wiki/Triboelectric_effect
« Last Edit: February 25, 2018, 11:21:54 pm by Mr. Scram »
Offline TheSteve
  • Living the Dream
« Reply #2 on: February 25, 2018, 11:34:29 pm »
I get that when vacuuming the couch with our V8 - it keeps you awake and reminds you that you're alive :)
VE7FM
Offline ogden
  • Country: lv
« Reply #3 on: February 26, 2018, 12:14:08 am »
Actually material combinations are well known. Even in wiki article there's list of Triboelectric series. Cat litter is not pure clay, even natural clay itself contain other minerals such as quartz (mostly positive) which is quite far from plastics (mostly negative) in Triboelectric series. So, everything was as it should be - sparks flying :)
« Reply #4 on: February 26, 2018, 12:22:32 am »
Interesting, thanks. I noticed if I hold onto the aluminum extension tube it seems to prevent a charge from building up so maybe I'll try adding a static discharge wire between that and the hand grip. It's quite a bit more potent than the typical doorknob on a dry day zap, I worry that it will damage the electronics in the vacuum as it has one of those fancy electronic brushless motors. It's also quite painful and unpleasant to get shocked repeatedly.
Offline Mr. Scram
« Reply #5 on: February 26, 2018, 12:48:07 am »
You're misunderstanding me. There isn't really a good rule of thumb what material interacts how with what, although we obviously have empirically established that the other way around by now. That's not the same, though.
Offline John Heath
  • 2B or not 2B
« Reply #6 on: February 26, 2018, 02:07:47 am »
I found a trick for the door knob surprise that could be used for the vacuum cleaner surprise. I came to a point that I could not touch the door knob without swatting at it first just to get the electric shock over with. My solution was to carry a HV 100 M ohm resistor in my pocket. When it came time to touch the door knob it would be done through the 100 M ohm resistor. It still makes a spark but you can not feel it. A HV 100 M ohm resistor from the charge plug to the vacuum handle should do it. This way you will be continuously discharging the static charge but at a low current so you will not feel it. Not a bad suggestion to pass on to the manufacturer of the vacuum cleaner.
Online Brumby
« Reply #7 on: February 26, 2018, 02:49:42 am »
Same trick - but I use my keys or some other metal object if I don't have my keys on me.
Still get the spark - sometimes with a resounding crack - but the point source comes off the metal, not my fingers.  I daresay the much greater contact area between my fingers and the key allow the passage of current to pass unnoticed.
Online amyk
« Reply #8 on: February 26, 2018, 04:00:12 am »
Even making the plastic casing slightly conductive would probably solve this problem.
There's a similar problem with treadmills (the ones you walk/run on) --- those can deliver a powerful shock if the belt isn't grounded to the frame with a "collector", since they basically form a horizontal Van de Graff.
Offline floobydust
« Reply #9 on: February 26, 2018, 04:55:46 am »
It's important - vacuuming your PC or any electronics, or using compressed air to blow out dirt, makes a lot of static electricity.
I've seen many techs damage boards by simply cleaning them this way. 3M has their anti-static vacuum cleaner, conductive plastic hoses.
Offline Tomorokoshi
« Reply #10 on: February 26, 2018, 05:53:06 am »
Get a soft lead pencil, grind it up, and vacuum up everything? Perhaps the graphite will coat the inside and make a dissipative layer. Or just work it in some other way.
I've seen vacuums for sawdust with a wire running down the length of the hose to vacuum motor to dissipate static. Dusts can be explosive, and the spark could set it off.
« Reply #11 on: February 26, 2018, 05:54:43 am »
I used to regularly clean PCBs using compressed air, then I read about the static issue and stopped doing it. I can't conclusively say that I have ever damaged one that way but looking back I do suspect a few incidents.
With the vacuum I found I can hold onto the aluminum wand instead of just the handle and that keeps a charge from building up. I'm really tempted to add a discharge wire or paint a track of carbon paint from the wand attachment to the handle. The thing that surprised me the most was the fact that of all the various things I've vacuumed up, kitty litter is the only thing that has been giving me shocks, and they're impressively powerful.
I once had a pair of sneakers in which the fabric covering the inner sole had come loose and would rub on the foam as I walked. Just walking a few feet and touching a metal object was enough to give me a powerful shock.
Offline Red Squirrel
« Reply #12 on: February 26, 2018, 07:31:42 am »
I had a funny incident like that once.  I was experimenting with trying to get chemical smell out of my couch because my cat pukes so much and after dousing the couch with every chemical I can find to try to get rid of the puke now all I could smell was the chemicals.  So I tried to just pour an entire box of baking soda on it and let it sit for a day or two.  When I vacuumed it up with the central vac it created a crazy amount of static, considering it was dry powder going through a very long plastic hose!  I was almost like Palpatine shooting lightning from my arms while vacuuming.   :-DD
It ended up causing an issue with a nearby temperature sensor and I had to reset my home automation system to get the sensor to work again.
I imagine with some kind of high speed air pump and plastic tubing loop with baking soda in it you could make a pretty decent van degraaf generator.  One section of pipe could be metal with a rod sticking out and it would probably discharge quite nicely.
Offline ogden
  • Country: lv
« Reply #13 on: February 26, 2018, 10:28:15 am »
Other option is to ship vacuum cleaner with ESD heel strap, something like this:
http://ultrastatinc.com/ESD_Heel_Strap_for_Static_Control.html
Actually those who tinker with electronics (even at home), shall consider ESD footwear in their lab:
http://www.antistat.co.uk/section.php/151/1/esd-shoes
« Last Edit: February 26, 2018, 10:51:03 am by ogden »
Offline ogden
  • Country: lv
« Reply #14 on: February 26, 2018, 10:49:11 am »
High-pressure compressed air indeed is not the best tool for the job, especially when board you are cleaning, is not grounded to you and/or air nozzle. Better use "canned air" which is actually not air but mostly butane, also ground device you clean - strap it to yourself using ESD strap. Using "canned air" there is another danger - possibility of combustion/explosion :) So ventilate your electronics well after cleaning & before switching it on.
Offline Terry01
  • Country: scotland
« Reply #15 on: February 26, 2018, 11:06:01 am »
I have 2 things here......
No1. Get the Mrs to do the hoover thing and I guarantee you won't get no more shocks from the hoover....can guarantee it 100%!  8)
No2. Cleaning with compressed air;
I used to work in the building trade...Roads and sewer gang.
One hot summer day our hired in for the week 360* track machine operator was moaning about the dust in his cab, he was going his duster about trying to keep it clean for the regular operator and when he was stuck in there all day breathing in all the dust. The young lad who worked with us said he'd seen another operator cleaning his cab out with the compressor hose for the jack hammer etc....
I've seen this before and i nearly broke my neck running for the other 2 guys in my gang when I heard the 2 talking about doing this. This couldn't be missed! These things pump out about 8 bar or more or well over 100 odds PSI!
These 2 were going to blast the open end of the hose into a dust filled 360* digger cab!
It can be done if you slowly open the valve but it's a crap way to do it at the best of times...I knew this wasn't going to be the case with these 2! I couldn't wait!!  >:D
The operator took the hose cause he wanted to be in charge of the operation and the young lad was in charge of opening the valve...the driver shouted "RIGHT" there was a massive WHOOOOOSHHH and the service manual and all the drivers check sheets etc went flying over his head just as he disappeared into a massive dust cloud!  :-DD  :-DD
He went nuclear and the look on the young boys face was priceless as the dust settled...the tears were rolling down my face i was laughing so hard! The other 2 guys and i were killing ourselves laughing when one of them asked "do you think it needs another quick blast driver"?  :clap:  :-/O
Funny as hell! One of the funniest things i've ever seen! Don't try this at home kids!  :-+
Sparks and Smoke means i'm nearly there!
The following users thanked this post: SeanB, james_s
Online amyk
« Reply #16 on: February 27, 2018, 03:16:07 am »
Canned air is usually a nonflammable fluorocarbon. It used to be R-12 in the good old days... but I'd be very surprised if it's butane now, because butane burns explosively and really, really well.
The following users thanked this post: Kilrah
« Reply #17 on: February 27, 2018, 05:38:31 am »
I have a can of air duster here, it says it's difluoroethane. They add stuff to make it taste bitter to prevent inhalant abuse, makes it smell bad too. Personally I'm of the opinion that if someone is dumb enough to inhale air duster to get high, there's no point in trying to protect them from themselves.
« Reply #18 on: February 27, 2018, 06:36:08 am »
That bitterant stuff is nasty!  At a place I worked we used to prank each other by freezing the thermostat so the heat would kick on even if it was hot in the room.  We stopped that pretty quick when they switched the cans to the ones that have bitterant.  :-DD
That said I'm not a fan of air dusters, it's so wasteful.  I prefer an air compressor.   Just need to be careful about moisture.  You can get air dryer attachments but was never able to actually find some so never bothered, but if I was doing it a lot I'd look harder to try to find some.
Offline ogden
  • Country: lv
« Reply #19 on: February 27, 2018, 07:41:22 am »
Did my homework. #1 choice of today's dusters is 1,1-Difluoroethane. Not as explosive as butane, but far from nonflammable: "Hazard statements : Extremely flammable gas."
https://www.airgas.com/msds/001090.pdf
You are right. I was ill-informed with 20th century knowledge.
« Reply #20 on: February 27, 2018, 04:42:58 pm »
I too prefer an air compressor, but there are times when the portability of the canned air makes it worthwhile. I can't easily drag my air compressor around the house.
« Reply #21 on: December 26, 2018, 06:01:48 pm »
A better solution would be a ground wire connecting the extension tube to a conductive pad on the handle to keep the charge from building up. I've formed a habit of grasping the tube with my left hand while using the vacuum.
The following users thanked this post: NiHaoMike
Offline Domagoj T
  • Country: hr
« Reply #22 on: December 26, 2018, 06:28:31 pm »
Some shopping centers have horrible static around them. I don't know if it's the floors or what but, whenever I'm in one of those I insist on being the one to push the cart. That way I can bump a metal shelf to discharge every couple of aisles.
Offline GeoffreyF
« Reply #23 on: December 26, 2018, 06:32:50 pm »
Actually, the pain one experiences from static is NOT a shock.  The discharge ionizes air creating a shock wave (however tiny).  That's what you actually feel, not a shock.  You can test this by discharging the static with a piece of metal such as a wedding ring, paper clip or whatever.  Obviously the same energy is conducted to your finger in this way but you will feel nothing.
None of this is to say that static discharge cannot harm electronic equipment.  It can. It does.  The damage is also not necessarily completely destructive.  It can degrade a part making it less reliable.  In a computer this would show up as more frequent crashes.
US Amateur Extra W1GCF.
Offline apis
  • Hobbyist
« Reply #24 on: December 26, 2018, 06:48:16 pm »
But in that case the energy would be spread over a much larger area, so one would expect it to hurt less.
