Hey everyone! I'm a new member of the forum so hopefully I've done everything right
As a side project I'm trying to read my old Samsung S4 memory chip with the t48, unfortunately I think during removal i toasted the emmc a little too much and I've damaged some memory sectors.
I've found, however, that most of the memory is still readable if I jump around so I was wondering if anyone knew a method of 'skipping' the error automatically once it is encountered.
I can write c and python if necessary, so suggesting some tinkering is well accepted. Something like accessing the t48 programmatically via some sort of api would be the perfect solution probably, so I can write the logic of padding bad memory myself.
I attach the logs of the xgpro if anyone is intrested.
Thanks in advance for the support
