To be honest, this sounds like an illusory problem. The most likely reason for reception to degrade with time is the increase of congestion on the 2.4 GHz band. As your neighbors add wireless networks, you add more client devices, and everybody gets more non-802.11 devices operating on the 2.4 GHz band, everybody's reception gets worse. If a few people pump up their Tx power to try to compensate, it makes it worse for everybody (and doesn't really help them either). To top it off, bandwidth expectations continue to increase, so what was a good signal 2 years ago might be 'barely working' today.
If you get a new router with a newer standard, a upgrade to 5.6 GHz, or get a router with more antennas for MIMO, you recover some of what you lost. Unless you do side-by-side comparisons of new vs. old routers of the same model with the same configuration it is going to be really hard to separate router failure from external causes.
Gradual signal degradation is certainly possible for instance if the PSU filter caps start to fail and pass more RF noise into the analog supply, but 2 years is a bit fast for that and it seems unlikely that would be a systemic problem across multiple manufacturers and product lines.
