Author Topic: Strange specs for a toroidal transformer(?)  (Read 936 times)
Offline x86guruTopic starter
« on: March 19, 2024, 08:07:05 pm »
Hi All,
So this toroidal transformer is almost 6 inches in diameter, and around 2.5 inches in height.
The primary side only has one 120VAC winding and is rated at 103VA
The secondary side has two 55VAC windings @ 490VA each.
I've attached a picture of the label and the size of this thing.
What is going on here? Does the "103VA" primary side rating really mean that the primary side winding can only handle 850mA while the secondary windings can handle 8.9 amps each?
I assume the "103VA" is either an error (maybe should be 1030VA?)
I don't know the actual gauge of the windings; however, the wires coming out of the toroid are all ~16ga so I'm puzzled what is up with the 103VA primary side notation.
Can anyone clear this up?
Online Benta
Re: Strange specs for a toroidal transformer(?)
« Reply #1 on: March 19, 2024, 08:38:16 pm »
~100 VA looks about right for the physical size of the transformer.
I suspect a typo. Secondaty should probaly read 90 VA, not 490.
« Reply #2 on: March 19, 2024, 08:41:52 pm »
 :-DD
 :horse:
Offline BrokenYugo
« Reply #3 on: March 19, 2024, 08:45:46 pm »
Size lines up with whatever Hammond 1kVA toroid google found me.
Ohm it out? If I'm thinking right with it being near 1:1 it should have a near 1:1 turns ratio with near 1:1 resistance if wound with the same gauge wire.
Online johansen
« Reply #4 on: March 19, 2024, 08:46:19 pm »
Yeah thats easilly a 1kva tx
Online Benta
« Reply #5 on: March 19, 2024, 08:51:59 pm »
&%¤#"!/ Imperial units.
The tape measure threw me off.  :palm:
« Reply #6 on: March 19, 2024, 08:54:41 pm »
:phew: -- I thought you were really that dumb :)
« Reply #7 on: March 19, 2024, 08:58:17 pm »
I physically do not have it yet as I just bought it off eBay this morning. I'm hoping it's 980VA. I'll ohm it out and load test it when I get it. I was wondering if the 103VA was some special non-standard application. Must be an error
Offline thm_w
  • Non-expert
« Reply #8 on: March 19, 2024, 09:02:29 pm »
Its not an error. The rating beside the primary winding is probably magnetization current (no load current), 103VA = 1.2A. 0.86A
The load rating is definitely 490VA*2.
Which matches up with this post here: https://www.eevblog.com/forum/beginners/transformer-idle-consumption/
« Last Edit: March 19, 2024, 09:22:41 pm by thm_w »
« Reply #9 on: March 19, 2024, 09:04:48 pm »
Thanks, that makes sense. Except, @120v, wouldn't 103VA be 820mA?
Offline thm_w
  • Non-expert
« Reply #10 on: March 19, 2024, 09:22:18 pm »
Correct. 0.86A
Online Andy Watson
« Reply #11 on: March 19, 2024, 09:49:13 pm »
Oh Lee Crap! Is this amateur's half-hour?
It's using the same nomenclature as is used for resistors. \$103 = 1.0 \times 10^3\$, i.e. 1kVa. Which is congruent  with its physical size!
Offline woofy
    • Woofys Place
« Reply #12 on: March 19, 2024, 10:03:16 pm »
For resistors its not 1.0, its 10 x 10^3 =10k
The following users thanked this post: thm_w, tooki
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #13 on: March 19, 2024, 10:49:46 pm »
What is it, AA59902055?
https://hubbellcdn.com/ohwassets/HCI/Acme_Electric/Literature/SECTION-10.pdf
...It's less likely to find standard parts among transformers, I mean customs are pretty common, but these ratings look standard enough.  Might get lucky with a search :)
Don't see anything in there about primary VA though.  Seems a strange way to mark it, if it's magnetization.  If in doubt, I'd e-mail them.
Seven Transistor Labs, LLC
Offline tom66
« Reply #14 on: March 19, 2024, 11:11:53 pm »
Ironically, that datasheet has a typo on page 4 where the table lists powers from "425-800" "800-120" and "1200-1500"... perhaps the same engineer designed this transformer that wrote out that table!
The following users thanked this post: T3sl4co1l
« Reply #15 on: March 19, 2024, 11:32:45 pm »
It's a AA24598C. I tried looking it up earlier with no luck.
« Last Edit: March 19, 2024, 11:35:03 pm by x86guru »
Offline thm_w
  • Non-expert
« Reply #16 on: March 20, 2024, 12:48:33 am »
Yeah I'm probably wrong looking at it again, I see some on ebay where they listed both primary and secondary VA:
https://www.ebay.ca/itm/282019280411 (pri 665VA sec 625VA)
https://www.ebay.ca/itm/166566676953 (pri 495VA sec 480VA).
So either 1030VA or 1003VA would be the number if that is the case.
Which would give you an idea of the efficiency?
Online Benta
« Reply #17 on: March 20, 2024, 12:53:40 am »
Go with the EBay specs. Everyone knows they are the most trustworthy and reliable in the world.
The following users thanked this post: schmitt trigger
Offline jonpaul
« Reply #18 on: March 20, 2024, 01:39:59 am »
KW is proportional to weight.
We usd e 35 cm dia 10..15 cm thick toroid's dual P-S 120/240,  5..10 kW for our client, Furman Sound.
 See Bel-Fuse, Pliotron,   similar  toroidal transformers, typical size, weight.
Jon
Jean-Paul  the Internet Dinosaur
« Reply #19 on: March 20, 2024, 02:10:10 am »
I'm thinking now that AMVECO probably custom built these for another company that possibly requested the primary side be labeled with no-load current. I'm thinking this because 103VA does make sense like you previously mentioned for a no-load current and this specific model number seems to be custom and not a standard OTS available unit -- so maybe it was labeled based on a customers request.
« Last Edit: March 20, 2024, 02:11:48 am by x86guru »
« Reply #20 on: March 20, 2024, 08:01:10 pm »
I received the toroidal transformer today.
It has 14ga primary and secondary wires. No idea what the winding gauge is. Primary is ~.3 ohms, and each secondary is ~.2 ohms. I haven't load tested it yet, but the primary side is obviously not 103VA.
Was a great deal for $25 + shipping.   :)
« Last Edit: March 20, 2024, 08:41:20 pm by x86guru »
