Author Topic: Please recommend small analog oscilloscope  (Read 5203 times)
Offline barry_gTopic starter
« on: January 01, 2012, 06:09:25 pm »
I'd appreciate recommendations for a small analog oscilloscope.  By small, I mean smaller than a Tektronix 2200/2400.
I have a Vu-Data PS935 which is a nice size, but really want to upgrade to something faster (ideally 60-100Mhz).  I'd like to keep cost to below $500 used.  Any comments/suggestions appreciated.  No DSO's.
TIA
Offline Bored@Work
Re: Please recommend small analog oscilloscope
« Reply #1 on: January 01, 2012, 06:59:10 pm »
A new 100 MHz analog oscilloscope will cost you $1000, and that doesn't even cover your small size requirement. So it is eBay time for you.
Offline EEVblog
« Reply #2 on: January 01, 2012, 11:13:06 pm »
IIRC the some of the Hitachi analog scopes were quite small. e.g. V-212 series that I think comes in up to a 60MHz model?
This new BK precision looks pretty small:
http://www.bkprecision.com/products/model/2160A/60-mhz-analog-oscilloscope-with-probes.html
12.76 x 15.68 x 5.2"
Dave.
« Last Edit: January 01, 2012, 11:18:05 pm by EEVblog »
« Reply #3 on: January 01, 2012, 11:24:57 pm »
Thanks for the responses.  Yes, any other small analog scopes out there on the used market at 60Mhz or higher besides the BK Precision?
The Hitachi scopes mentioned are only 40Mhz or less.
Offline slateraptor
« Reply #4 on: January 02, 2012, 12:27:58 am »
No DSO's.
Curiously, why?
Late-80's, early-90's HP scopes are taller but typically smaller cross sectional footprint.
EDIT: Now that I think about it, those scopes were DSOs with monochrome CRT displays. :-\
Offline Psi
« Reply #5 on: January 02, 2012, 12:30:34 am »
No DSO's.
Curiously, why?
Don't worry. More DSO's for us  ;D
Offline tekfan
  • Country: si
« Reply #6 on: January 02, 2012, 12:47:35 am »
This is the only scope with >50MHz bandwidth that comes to mind.
The Tektronix SC504
80MHz bandwidth, dual channel, 5mV/div sensitivity, XY mode... what more could you ask from something this small.
The only drawback of course is that you have to plug it in a power supply mainframe with at least 2 compartments. (Tektronix TM502 or bigger)
There are a few on ebay now but for ridiculously high prices. It's best to wait for an auction and pick one up cheaply.
http://www.barrytech.com/tektronix/tektm500/teksc504.html
One can never have enough oscilloscopes.
Offline grenert
« Reply #7 on: January 02, 2012, 01:04:24 am »
The Sony-Tektronix 336 is a small 50 MHz analog scope with digital storage.  Only 11 lbs!!!  There is a similar model 335 without digital storage (I think), but only 35 MHz bandwidth.
http://www.tekpool.ch/Specs/336.pdf
« Reply #8 on: January 02, 2012, 01:20:34 am »
Thanks, the SC504 and 336 look to be viable options - I'll add them to my watch list.  The SC504/TM500 is a sweet looking system.
« Last Edit: January 02, 2012, 11:45:38 am by barry_g »
