I seek opinions on using standard through-hole clock oscillators to generate 'test-patterns,' if you will, that I can pump through my oscilloscopes, and my eventual o-scope project...
COTS frequency generators appear to be freeking expensive for anything above 5Mhz or so. I do have my eye on the Rigol DS1022 20Mhz for approximately $700US, but I have a feeling I'm going to outgrow that limit fairly quickly. The 120Mhz unit is about $4000US-- I don't think I would use it enough to justify that kind of purchase. However, paging through my favorite Digi-Key catalog, I see that there are myriad crystal and/or oscillator offerings-- could I simply provide the requisite +5v / +3.3v to the OSC can and use the output for testing? I could simply buy 10-20 OSC's in xMhz steps to get to my 120Mhz requirement! Are there limitations in doing so? What kind of circuit (apart from power) would I have to build in order to support this?
And finally, if I wanted to amplify these signals (and change the amplitude displayed on my o-scopes,) could someone recommend a circuit that I could build to do so? I would assume that an op-amp or two would be sufficient....
As for my O-scope project, I'm looking to build a three-chip DSO out of a PIC32, AD9283 ADC, and FIFO-- for no other reason than to learn about microcontroller development, ADC's and FIFO's.! But step one, in my opinion, would be to have the capability to produce a signal of known quantities/qualities.
Any and all assistance, comments and opinions are sincerely appreciated!
-Trent
