Hi everybody,
I had bought this amplifier from aliexpress some times ago the model is zk-mt21.
The amplifier accept a tension from 12 to 24 volt for supply, as you can see in the image there is a 25 voltage electrolitic capacitor.
The problem is that I want to give supply from two lead acid battery and the voltage of the battery can go from 23 when empty and 27 when charging from the solar panel.
I connect my amplifier to a 22volt power supply and I see that rarely it consume more than 1.5 ampere continuosly.
I want to use some 10A diode in series of my amplifier to lover the voltage for that 3 volt.
But every time I search for lower voltage with diode everybody become crazy because of inefficienty.
I know I can use a dc dc converter for lover the voltage to 18 volt, but I want my setup to be simple, and a step down that can handle 10A is a bit too much for that.
Everyone have some suggestion? thanks
