Author Topic: SurgeX (Ametek) UPS-2000-OL Online Double-Conversion UPS (2000VA/1800W)  (Read 489 times)
Offline Demon CoreTopic starter
Hello forum, I found a brand new in box SurgeX (Ametek) UPS-2000-OL with a retail of over $2,000.00. The price was too good to pass up so I snagged it. I have an NVR 16 channel security system, router, alarm, etc. I could hook it up to or power my TV, AVR for a brief period of time. Does anyone have direct experience with SurgeX (Ametek) online double-conversion UPS'? I'm also worried it will be too noisy since the fans run continuously as an online unit. I believe it's rated for <50db at 1M, but I have no idea how that translates in the real world until I receive it. SurgeX is very well known in the audio/video/home theater world for their Advanced series mode protection devices as opposed to typical MOV surge protectors. Here are the specs:
SurgeX online double conversion standalone UPS battery backup solutions deliver clean continuous power, via online double conversion technology, to ensure the safe shutdown of equipment in the event of an outage. All incoming power is converted from AC to DC and then back to AC. If the main power is interrupted, the batteries are still holding up the incoming DC supply to the inverter, so the load continues to be supplied with absolutely no interruption whatsoever. The zero transfer time guarantees mission critical equipment remains up and running.
~Online double conversion technology
~True sinewave output
~Controllable receptacles
~Hot swappable battery
~Configurable as tower or 19” rack
~Intuitive LCD screen
~Optional SNMP card to monitor and manage the UPS via the network
The UPS-2000-OL shall be a two-rack-space or tower on-line UPS unit in a steel and plastic enclosure. It shall operate at 120 volts AC at both 50 or 60Hz and have a 6-foot, grounded, 3-wire #12 line cord. There shall be 5 grounded AC receptacles on the back panel. This unit can accommodate additional battery cabinets to extend its autonomous run time. Overall dimensions shall be 3.39” H x 17.24” W (or 19.0” W with ears) x 20.20” D. Weight shall be 58 pounds. The UPS-2000-OL shall have a total load rating of 2,000VA / 1,800 Watts. This unit can accommodate an optional SNMP network card for unit monitoring and shutdown.
« Last Edit: August 29, 2021, 05:29:26 pm by Demon Core »
