Whaaaa?
20A at 220v = 4.4Kw
100VDC at 50A = 5Kw
One circuit has more than one outlet on it (usually 10 or more), and miniature circuit breakers are generally only available in common sizes. 4.4kW at 100V is 44A, next biggest size of commonly available protective device is 50A. Smallest cable with a great enough CCC before taking into account derating factors is actually 16mm2 (I made a mistake before) and that is without considering fault loop resistance and voltage drop.
That sounds fanatic to me. In the USA, we use 120V at 15A for the vast majority of household needs. Only hairdryers and toasters max a circuit like that. Circuit protection is CHEAP whether its DC or AC.
As I've said above, that one circuit might have your hair dryer, hair straightener, toaster, TV, xbox, microwave oven, and PC all on the one circuit, all running at the same time. Putting a single outlet on a circuit is just silliness. In Australia we have a similar system to Europe, our general purpose outlet is 230V 10A, and that is what is used for >90% of domestic appliances. You might need a 15A or 20A outlet for welders, small lathes, etc. or large kitchen appliances for example, and generally those outlets have dedicated circuits. I suppose if an entirely new system was introduced you could get away with smaller general purpose outlets, but I (as well as probably a lot of people) really like the simplicity of only needing one type of outlet for most commonly used items
