Distance, and corrosion across dissimilar metals,
How do you step up a DC voltage from 300V to 11KV at 100A?, With DC, it involves multiple electronic parts with a low margin of overload, with AC its a block of metal with wire, that has an efficiency bloody close to 100%
what happens when you mix aluminum clad steel wire with copper wire or joiners, with AC, as the current flow reverses many times, you end up with only environmental corrosion, with DC, it is amplified and things break down faster,
And finally the most important one for the power grids, AC sparks are self extinguishing in most cases, the current falls to zero 50 or 60 times a second, and providing there is enough gap it will stop, with DC it wont, this is not just relevant in faults, think what happens when you open a switch contact, you need a more complex design to ensure the larger required gap is provided when the contacts are separated,
For local in house, sure rectify and use to your hearts content, but play with big power and its not worth it, even a little,
