Author Topic: SWMBO Just Dropped Her Phone in the Toilet  (Read 1876 times)
Offline German_EETopic starter
« on: December 19, 2019, 08:10:23 pm »
Fortunately it was water in the bowl and I got to it only minutes after the incident.
I've stripped it down, washed all the parts I can access in IPA to displace the water and then left it to dry off. It's a clamshell phone and the display half appears to be glued together so that bit has been left alone.
Neither the microphone or speaker are MEMS devices so they might survive.
Is there anything else I can do ?
Warren Buffett
Offline VK3DRB
Re: SWMBO Just Dropped Her Phone in the Toilet
« Reply #1 on: December 20, 2019, 05:57:52 am »
Rule number one: Take the battery out ASAP to prevent electrolysis.
You infer that you might have removed the battery. And with the battery out, place the phone in an oven on the lowest temperature setting for an hour. Do not let it exceed 70 deg C, because some speakers and mics are only rated to 70 deg C. If you are in Europe, it won't dry out properly at this time. (In Melbourne, it is forecast to reach 44 deg C (111 deg F) today, hence it would dry out here easily).
Then have a word to SWMBO and find out why she was using the phone in the toilet. You need to get to the bottom of this.
Online Bud
« Reply #2 on: December 20, 2019, 06:03:18 am »
Wow, they still make clamshell phones? How old was it, maybe it was a godsent sign to change it  ::)
Offline cliffyk
    • PaladinMicro
« Reply #3 on: December 20, 2019, 06:18:20 am »
No pun intended, right!
-cliff knight-
paladinmicro.com
Offline Halcyon
  • Global Moderator
« Reply #4 on: December 20, 2019, 07:36:40 am »
Where else does one read the EEVblog forum and watch Youtube? ;-)
The following users thanked this post: Electro Detective
Offline Electro Detective
« Reply #5 on: December 20, 2019, 08:52:34 am »
Not sure about putting a phone in the oven,
but a hair drier or small fan heater blowing at the raised up phone in a stiff carton box from a distance has worked for me for other moisture invaded electronicals
Now let's be straight up here, surfing the phone in the womens powder room isn't anything new or illegal,
but dropping it in the dunny earns one a heavy duty  :palm:
Why is it always the ladies teaching their life support device to swim ?
Men rarely do it, if ever  :-//  and they've got more to handle  :P
Offline HackedFridgeMagnet
« Reply #6 on: December 20, 2019, 09:02:23 am »
she's in good company
Offline SparkyFX
« Reply #7 on: December 20, 2019, 11:23:38 am »
In case the hair dryer and oven sound too risky.... you can place it covered in rice within a container to soak up the humidity.
Support your local planet.
Offline Halcyon
  • Global Moderator
« Reply #8 on: December 20, 2019, 11:34:50 am »
An oven is perfectly fine as long as it has a "warm" setting. Middle shelf, away from the elements. Limit the temperature to 60-65 degrees. Remove the battery.
Otherwise I use a food dehydrator at work to restore circuit boards which have been washed and cleaned after being in the ocean. A few hours at 55 degrees is normally enough.
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #9 on: December 20, 2019, 11:49:52 am »
I think you did good with rinsing it with IPA and then drying it out. Whether you use an oven or a hair dryer or just leaving it on the radiator doesn't really matter. The most important thing is anyway to switch it off ASAP and remove the battery.
Rice doesn't do shit. But after you did all the other things, it won't hurt. It also won't help.
Offline Halcyon
  • Global Moderator
« Reply #10 on: December 20, 2019, 12:11:01 pm »
It does. It gets rice particles and starch inside every little groove and port.
Offline kosine
« Reply #11 on: December 20, 2019, 12:35:10 pm »
Rice grows in paddy fields, which are kind of wet. If it readily absorbed water we wouldn't have to boil it!
Anecdotes about it drying phones are mostly due to putting it in a warm environment and letting the water evaporate. Rice by itself doesn't work.
Best technique is water gel crystals as used by gardeners. (Sodium polyacrylate / acrylic acid.) Ideally get the coarse stuff rather than the fine granules. Put them in an air-tight container and place the phone on top of the granules. Don't cover it - you need the air space. Seal it and leave it for 24 hours. (Preferably somewhere warm, but I've actually tested this in a fridge and it still works, even at 5C!)
The granules will pull moisture from the air in the container, the phone will give up moisture back into the air. I've used this technique many times, and it's pretty effective. The phone may still be damaged, however, and some will lock up having detected a fault. An iPhone 6 I did a year or two ago went into recovery mode, but was accessible by a PC after drying. So you should stand a chance at recovering data if nothing else.
Offline thinkfat
« Reply #12 on: December 20, 2019, 12:35:28 pm »
 :-DD  :-+
Offline macboy
« Reply #13 on: December 20, 2019, 03:43:00 pm »
Definitely reach for distilled/deionized water as the first cleaning agent. Water is polar and will remove salts, acids, and dirt (all present in toilet bowl water!) that non-polar IPA doesn't readily dissolve. And unlike tap water or dirty water (containing urine etc), it isn't conductive. Then hit it with the purest IPA you have (preferably >=99%), and lots of it. The goal is to remove as much water as possible.  The IPA will preferentially evaporate until the remaining residue is about 91% IPA to water (the azeotrope point). Then that mixture will evaporate together relatively easily and completely, compared to just water.
Some have mentioned using an oven. Mine has a bread dough rising setting, roughly 55 C or 130 F, and this would work nicely.
Offline SiliconWizard
« Reply #14 on: December 20, 2019, 04:17:35 pm »
Or at least this is what she said... >:D
« Reply #15 on: December 20, 2019, 06:09:08 pm »
OK, panic over, I just put it back together and apart from some cosmetic damage on the left side of the display everything is OK. Apparently it slipped out of her jeans as she sat down on the pot.
I did consider using an oven after reading some of the comments but I don't know the minimum temperature, so I left it overnight on my GPSDO which is comfortably warm. Thanks for all the suggestions and comments, I'm just grateful that it wasn't an iPhone or something else that is glued together.
Warren Buffett
Offline Gyro
« Reply #16 on: December 20, 2019, 08:07:17 pm »
As the sign usually says:  "Now wash your hands".  ;D
Best Regards, Chris
Offline SparkyFX
« Reply #17 on: December 21, 2019, 04:41:51 pm »
Maybe you should not try boiled rice...! (remembers me of the collision tests with frozen birds)
