I got this Samsung ps42b430p2wxxu, Symptoms are it's clicking on and off repeatedly. I took off the cable "pic1 pen pointing too" And the tv started up. So I think im right in assuming it the y sus board at fault. The set was turned off strait away once it went bad so im gonna assume the x board is ok. looking at the y board there is no obvious fault but I did some component tests and this diode here is reading 0.0012 both ways on a diode test. surely its a faulty diode???
