Author Topic: Storage/Parts boxes  (Read 19325 times)
Online David Hess
  • DavidH
Re: Storage/Parts boxes
« Reply #50 on: July 30, 2017, 07:29:36 pm »
Ammo cans are way too big and you can't see into them making it a bit harder to know what you're getting.
Watch out when using ammo cans to store anything.  They seal well enough that outgassing can be a problem if the gases will react with other things stored in the ammo can.
For people in Australia looking for a good option, I propose these
http://www.fischerplastics.com.au/product-range/clear-storage-boxes.aspx
Comes in various sizes with various sized compartments.
I have some similar ones and they are very nice.  The insides of the compartments are even curved so small parts do not get stuck in the corners or edges.
The problem I have is that whenever I find some, they are discontinued after I buy a bunch so now I have several collections which do not match.
« Last Edit: July 30, 2017, 07:34:46 pm by David Hess »
Offline TimInCanada
« Reply #51 on: August 02, 2017, 02:44:57 am »
Here's a question about the plastic food tubs and ESD.  I've also been using them for larger bits like scope probes, driver sets, etc.  There are some things (e.g., Bus Pirate, FTDI cable, etc.) that are static sensitive to some degree.  Is there a danger of these plastic tubs creating ESD when moved around?
Offline jh15
« Reply #52 on: August 02, 2017, 04:06:51 am »
I've made Layden jars from Tupperware and other food plastic containers. Hold thousands of volts of charge for a long time :)
Tek 575 curve trcr top shape, Tek 535, Tek 465. Tek 545 Hickok clone, Tesla Model S,  Ohio Scientific c24P SBC, c-64's from club days, Giant electric bicycle, Rigol stuff, Heathkit AR-15's. Heathkit ET- 3400a trainer&interface. Starlink pizza.
Offline Rbastler
  • Wörk Wörk
    • Rbastlers Blog
« Reply #53 on: August 02, 2017, 07:10:13 am »
https://www.amazon.de/Stanley-Kleinteilemagazin-bruchfester-Kunststoffrahmen-1-93-980/dp/B008DHZXRC/ref=sr_1_1?s=diy&rps=1&ie=UTF8&qid=1490966641&sr=1-1&keywords=Stanley+Kleinteilemagazin
I found this boxes first in my home towns OBI. There also boxes with bigger compartments, but still the same sie. So you can easily stack them. I now use almost entierly those. Better stick to one system, instead of having a big varaiety of boxes. Unfortunatly the nearest OBI where I study doesnt have them. Luckily amazon does :D
Sent from my A0001 using Tapatalk
http://rbastlerblog.jimdo.com/
Gamma spectrometer works. Now some yellow crystals need regenerating and testing.
Offline TimInCanada
« Reply #54 on: August 02, 2017, 08:14:39 pm »
Thousands of volts?  Well, there goes that easy solution to storage...   :o
Online David Hess
  • DavidH
« Reply #55 on: August 02, 2017, 08:31:33 pm »
I bought a roll of black antistatic foam and cut out squares to fit into the bottoms of the drawers where I think this could be a problem.
Offline rdl
« Reply #56 on: August 02, 2017, 08:50:01 pm »
I did something similar for my Akro Mills drawers, except I bought a sheet of antistatic foam which is fairly stiff. I can fit two layers in a drawer and stick stuff in on both sides. I also keep a few small pieces on the bench to stick random stuff in so nothing gets lost.
Offline eugenenine
« Reply #57 on: August 02, 2017, 11:47:45 pm »
I did that back when I used those drawers but I learned the hard way to not use drawers
Online David Hess
  • DavidH
« Reply #58 on: August 03, 2017, 01:59:34 am »
I did that back when I used those drawers but I learned the hard way to not use drawers.
Did you knock a cabinet over?
Offline jh15
« Reply #59 on: August 03, 2017, 02:23:05 am »
I remember having early cmos stuff in black foam in drawers in the 80's. Looks like some or all is corrosive over time? I went to extract a chip, and there were no pins on it. Way before one-hung-low, and in an aerospace facility for test equipment repair.
Online David Hess
  • DavidH
« Reply #60 on: August 03, 2017, 03:25:12 am »
I do not remember the details but one of the plastics they used for foams was not stable in the long term and would rot releasing fumes.  I have not run across that with antistatic foam.
Offline eugenenine
« Reply #61 on: August 03, 2017, 01:17:05 pm »
I've knocked cabinets over, off the hangers, spilled the drawers, etc.  I make sure to always use boxes with latching lids now.
Offline jaunty
« Reply #63 on: September 22, 2018, 09:11:09 am »
Online David Hess
  • DavidH
« Reply #64 on: September 22, 2018, 11:39:19 pm »
Sometimes in expensive but nice polypropylene divided parts boxes with the hinged lids show up at Home Depot or Lowe's but I never buy enough of them.  The bottoms on mine are curved at the edges making it easy to finger parts out without them getting stuck in the corner.
The following users thanked this post: jaunty
