The memory backup battery on my Tektronix 2445A is starting to go flat. Normally, after replacing it, the whole calibration routine has to be run, because the damn thing doesn't even have factory defaults in ROM. I'm a bit short the necessary equipment (and time) to do a full, proper calibration, and it's currently spot-on so I'd like not to mess with it. Sadly there is no way to read out the constants and then write them back in. Would I have any problems doing something like this?
Connect a power supply to the circuit in parallel through a resistor (2-5k or so). This should limit current into the dying battery - I don't care if I damage the battery, since it's going right in the trash, I just don't want it to blow up. I'd imagine the backup current is low enough that the voltage drop in the resistor shouldn't matter. (I'd use the current limit on my power supply instead if it weren't so pathetically coarse at low currents.) Desolder the battery. Connect a new one with a series low-drop diode (BAT85S, VF around 0.25V for IF around 100µA) to protect it from the power supply. Disconnect the supply, short the diode for full voltage.
Any potential to damage anything here, besides the original battery? (Or any reason why it just plain won't work and I'll lose my cal constants anyway?)
