I once visited a company (for an interview) that built their labs as thermal chambers within thermal chambers, with yet another thermal chamber for the DUT. Both the inner and outer chambers were kept at 25C year round, and the DUT one was either held at 25C or varied as needed. They also designed the air circulation to account for the heat coming off the equipment.
Where I work now, the thermal control is much more lax and there are many spots that are as much as 5 degrees C or so cooler than most parts of the room. It looked really funny with some of the workers dressing up for cold weather in the middle of summer.
At home, I don't have anything accurate enough to require much temperature control so energy savings are the main deciding factor. It often can go as high as 28C (82F) during the summer and as low as 17C (63F) during the winter. I had it go all the way up to 31C (88F) once (unoccupied) in order to perform a thermal stress test on a new PC.
