Anyone driving a jeep cherokee can be anonymously remotely murdered over the internet right now.
F.U.D.
like remove tension from the seat belts
Not likely as the seatbelt mechanism has a centrifugal locking assembly in it which is actuated mechanically...no electronics here.
, do max acceleration,
Possible, but as has been shown in the Toyota Prius debacle, step on the brakes, turn the engine off, no problems here.
disable breaks
Everybody wants to "disable BREAKS".
However if you mean "disable BRAKES"...impossible, as even though the braking system is tied into systems such as anti-skid, anti-lock, etc., the fail-OPERATIONAL mode of any and all braking system is purely hydraulic. Barring any failures otherwise (eg. leaks, blockages, etc.), step on the brake pedal, brake shoes/pads actuate, car stops. 'nuff said.
and twist the wheel into a roll. _easily_.
NOT easily. First you gotta spin the steering wheel fast enough and have enough traction to make the vehicle roll over. Second, today's power steering system is a form of an electric power 'assist' system, NOT a steer-by-wire system...and they are easily overcome with nominal effort.
Nothing to see here...
Move along...
