You cant fix stupid. I see people reading books while driving, others have no idea how to to drive a car.
90% of my coworkers dont know how much following distance you need. 1 out of 10 actually said, it depends on the speed. Congrats to her, best answer. I see people going into situations where there is obviously no way of coming out, if there is something unexpected on the road. Like another car. That's OK, you can always just slam on the breaks and crash into everything slow.
Honesly, I think level 2 autonomus driving is just not safe. Level 1 is fine, also 3. But 2? You can release everything, but still need to pay attention. I dont think humans work that way. You cannot blame the autopilot, you were driving.
millennials the generation that think's technology will do everything for them, including drive the car. and maybe wipe there butt too!
The Japanese already perfect the latter, and a fine invention it is!
And the automated masturbating machine used by Chinese sperm banks.
Reading this, the gears in my technical mind instantly started turning, trying to come up with how an autonomous masturbation machine would be constructed.
It only took a few seconds to come up with a design. I’m picturing an armature connected to an off balanced rotating disk (like an oil well). Attached to the end of the armature is a Fleshlight(TM).
The Fleshlight(TM) would have a small hole drilled in the top, into which a small tube would be inserted. The tube would be attached to a small vacuum pump, allowing additional negative pressure to be created for the user’s pleasure (in addition to extracting the final deposit). You could even back feed a liquid through it so it would be self cleaning!
Hmmm... Patent, here I come. (No pun intended.)
