I see a relay bank used to generate the running light sequence, and a lot of junk PCB's cut and epoxied into tubes of acrylic in an acrylic case. Also a reed relay probably used to turn the power on and off. Batteries required, and the tape probably used to keep them in the holders so you would not need a retake of scenes because of poor contact.
