'MY' theory is that 'Gravity' is like the Kinetic/Potential energy of the proverbial 'Big-Bang'!!
We agonize over where it all started. Let's look at a 'Simple' physical construction, where there are two boards, held at a
distance between them. To all intensive purposes, between those two boards, there are two springs attached between them.
ONE has NO spring tension, and the OTHER has a 'force' trying to pull them together. All this seems perfectly feasible, BUT imagine
some external device/meter that you 'point' at it, or wave it around, that can measure/detect these forces?? You can't.
It's at(within) an atomic/molecular level. Your 'sensors' need to be within the atomic structure!! To my mind, it's LIKE that, when
people keep trying to 'measure/detect' Gravity Waves. It's a lost cause. I 'think' that possibly Gravity can only exist, as we know
it & imagine it, is because originally, ALL matter/energy was initially emanating from that single point at creation...
Imagine the Conundrum of 2 objects/matter 'materializing' in Space. Would the 'force' between them be instantaneous??, or
maybe have to travel at the "speed of light" or something first? Hang on, it's said that energy can not be created or destroyed, but
only transformed from one form to another or from one object to another... Yep. I propose also that matter is but a 'form' of energy!
'Matter' has been converted to energy as in E = MC2 in nuclear explosions. And vast amounts of Energy have, in particle accelerators
or atomic 'splitters' resulted in the re-creation of matter (Protons) as well as other 'particles'. So if matter is a form of energy, then it's
not a big leap to imagine the 'Big-Bang' (the source of it all!) to change how we 'try' to compartmentalize 'Gravity'. OK I'm done...
