I run a few sites on virtual servers, with various backup policies (which I won't write about openly for obvious reasons) and if the virtual server company blew up and vanished for ever, I could start up a backup server which is a media PC running on an FTTP (80/30mbps) ADSL line
That would actually be fast enough for EEVBLOG, on a bad day.
And how would you know how much bandwidth EEVBlog uses each day? Outgoing traffic averages 90mbps peaking out at 200mbps during high activity periods such as giveaways, etc.
It is practically impossible to lose everything, in this setup, and it is very cheap.
What if someone deletes all the files on your server and rsync does it's dutiful job and deletes them on your home machine? Or worse, some files are corrupted and you dont detect this for a few weeks? rsync is not a recommended enterprise grade backup solution, I suggest you look into BareOS (Free), or R1Soft (commercial).
EEVBlog is backed up daily to two remote locations with a 6 month data retention policy, restoration to a bare metal server can be done in an hour or two (depending on network speed) and server configuration is performed via Puppet, this takes mere seconds. Total production ready stand-up time form bare metal is restore time + 10-20 seconds. With a warm backup (which we will be looking into) downtime would be nearly zero in the event of a failure like this in the future.
One has to weigh up the time vs cost in standing up a new server when things like this happen. Sure, Dave could have paid for a server elsewhere (in fact, we had several offers of temp servers), however this makes things more complex when it comes to decommissioning these servers when they are no longer needed. Ie, sync temp to primary servers, change over DNS records and while waiting for DNS records to propagate proxy traffic to the primary servers from the temp server. At the end of the day, it's up to the site owner to decide on the best course of action for their business, even if there are technical solutions that could be implemented here and now.
When you start hosting sites the size of EEVBlog you will quickly learn that you can't just cowboy things, because that 0.5s of downtime when you decided it wont hurt to just restart the HTTP service to make a config tweak, will impact people.
