most old big projects that engineers find cool are basically falling apart because they are said to not benefit the military anymore and most people are super cheap and military applications usually do not allow you to boil a design down to shady levels, so now that the military is left out of things and deemed not important the projects start to suck and maintenance is not had. At least, its a small part of the reason why. In America like 30-40% of the bridges are fucked up (and I shudder to think what the number would be if German engineers that live in Germany and are culturally German would rate the % at given by the quality difference of 'entry grade' German and American products!). Really thrilled to drive to certain places where you can become jam in a cement sandwich because someone does not wanna paint some stuff and replace some bolts. I feel like the people that ignore this and still drive under it every day are some really driven psychopaths (super common for people to show solidarity to people neglecting infrastructure for some reason to show that you are brave and badass. I mention it in the car driving near a suspicious object and you might as well put a fucking barbell in the car and have someone do a 500 pound lift and start gloating about it).
of course its hateful, bridge collapses kill people, like the one in Italy recently. Possibly a similar principle to this telescope, ignore corrosion in load bearing members. Granted the ones in bridges are pretty insidious, I had a granite countertop crack because a metal bar potted in epoxy some how put rust pressure on the granite. You would really need to trust corrosion engineering best practices and forgo your own intuition (as you should) to see that one coming because based on 'common sense' it should not have happened, but if you read about what happens with epoxy and iron, its plainly shown as a regular occurance.
these projects are really interesting if you find 'damn he really squeezed everything he could have out of the companies preferred FEA method! look how he fooled everyone into not making a real life experiment first' interesting and or cool.
BTW I noticed in Poland when I was driving around too many things had a nice heavy coat of rust and dilapidated failing paint on it. All the rusty property fences looked wonderful. Old historical towns with a middle aged feel still had the same rusty moss covered roofs, its like if you plated the renaissance with cheap communism
. Beautiful victorianish house with a black mold, weathered paint and rust covered soviet grain house roof right near the town hall that looks like its from a fairy tale.
