I'm late on this topic, + the time to read all the previous pages
I do agree USB-C *may* be a solution to harmonize sockets on portable devices, but there are many issues and questions left in my opinion.
- All HAM operators in the VHF/UHF already noticed that most if not all manufacturers (Yaesu, Icom, Baofeng etc.) have proprietary charging and data cables on most of their portable and handheld radios. It may change in the near future but in my case I'm stuck with different sockets, for example in my Icom, Yaesu and Elecraft devices the RS232-USB cable is in the form of a 3.5mm stereo or trrs jack. Not really standardized, and definitely not USB-C. I hope it will change.
- Putting USB-C sockets on mobiles devices doesn't solve the "hub" issue, when we want to charge/connect multiple devices. There is no daisy-chaining possible, and I assume there are not any cheap hubs with multiple USB-C outputs. I said USB-C, not Thunderbolt (which is a sophisticated but very expensive solution). So users are left with USB-C to USB-A cables as the only solution to plug/charge several devices on a laptop, unless this laptop has several USB-C outputs which is uncommon (except on expensive models, and in that case it's Thunderbolt ports), or if they buy expensive Thunderbolt or dedicated docking stations (In my case I have a Surface Laptop Go, and had to buy the $300 Microsoft docking "brick" with its proprietary Microsoft Surface cable, to add the 3 more USB-C ports on my laptop). Definitely not cheap nor convenient. I had a (quick) look at the Thunderbolt and USB characteristics, and it seems that only Thunderbolt is capable of daisy-chaining, and offering multiple USB-C outputs, do correct me if I'm wrong.
- Another thought I have about those USB-C connectors is their use in industrial environments. I'm used to USB-B connectors for my lab devices (Siglent, etc) but also other "heavy duty" gear because it's more prone to be in environments with risk of damage. I just wish that even if USB-C is enforced for small devices, USB-B or an equivalent of a rugged USB-C will continue to be available for those devices. The Wikipedia overview of USB connectors seem to demonstrate there is nothing planned other than the small USB-C connector for rugged environments.
https://en.wikipedia.org/wiki/USB#Connector_type_quick_reference. I simply can't imagine industrial equipment in hospitals, factories, aircrafts etc. using fragile and prone to accidental disconnection USB-C sockets.
An analogy is the HDMI sockets are "consumer grade" and fragile, but in the professional environment devices are fitted with SDI BNC sockets, which are much more reliable, solid, allow longer lengths of cables, are locked (BNC) to prevent accidental disconnection, etc.
As an individual and hobbyist, I can't change anything on this, and will passively overlook the manufacturers endorse USB-C for everything, but I anticipate those issues mentioned above in the future !
