Author Topic: Trying to find manufacture of socket  (Read 1734 times)
Offline forthnutterTopic starter
« on: November 29, 2018, 01:26:47 pm »
Hi all, I am trying to find out the manufacture or part number of this socket, used a lot on old CRT deflection yokes. I originally thought it was Utilux or Molex part. I did have an old Utilux catalogue didn't find anything so far. The spacing between the two H is larger then the spacing between the two V's.
Offline MrMobodies
Re: Trying to find manufacture of socket
« Reply #1 on: November 29, 2018, 03:33:00 pm »
I have searched and found that Sanyo CRT tubes used similar style ones for game arcades.
https://quarterarcade.com/sanyo-20-z2aw-19-yoke-and-color-rings
The placement is a little different and I am not sure if they will fit they all look non standard.
https://www.ebay.co.uk/itm/Connecteurs-Yoke-ecran-CRT-Sega-Astro-City-Borne-Arcade-Jamma-Nanao-MS8-Toshiba/173621744221
https://forums.arcade-museum.com/archive/index.php/t-355710.html
It looks very similar apart from the round corners and the edging on the H which is in the center.
« Last Edit: November 29, 2018, 03:35:17 pm by MrMobodies »
« Reply #2 on: November 30, 2018, 11:33:32 pm »
Thanks for information.
I found JST make a similar connector with the correct pitch called LV Series. A smaller version is known as V Series.
http://www.jst-mfg.com/product/detail_e.php?series=162
http://www.jst-mfg.com/product/detail_e.php?series=258
