While giving you dry eyes and a sore throat due to a draft of bone dry air. And the constant fan noise on top. No thanks. Nothing beats underfloor heating where it comes to comfort. Especially when it is close to the surface of the floor.
It's matter of taste. I know many people like the warm air flow and have enjoyed it myself too without sore throat. You don't have to use the max fan setting.
I'm not sure how heating air makes it dryer (it could feel dryer as there is higher evaporation rate). But it comes back to the simple point of how is that any different to another source of heating inside the room?
The ability for air to hold water vapor* is
highly temperature dependent: hot air can hold far more moisture than cold air. For example, 0°C air can hold up to 4.84g of water per cubic meter. 20°C air can hold up to 17.2g per cubic meter. If that cubic meter of 20°C air actually contains 17.2g of water vapor, then we say the relative humidity is 100% (17.2/17.2 = 1 = 100%. But if that same cubic meter of 20°C air contains only 4.84g of water vapor, then its relative humidity is just 28% (4.84/17.2 = 28%).
So if you start with fully saturated 0 degree air and heat it to 20 degrees, then its relative humidity will drop from 100% to 28%.
This effect is also why hot air is so much more effective at drying things than room temperature air: 100°C air, for example, can hold 598g of water vapor! That is a typical temperature for a hair dryer on high. So if we suppose your house is at 20°C at 50% humidity (so 0.5*17.2g = 8.6g per cubic meter), then the 100°C air coming out of your hair dryer has a relative humidity of just 8.6/598 = 1.44%!
However, I completely agree with your point that it makes no sense for one type of heating to dry out the air more than another. Every heating type is subject to the same laws of physics.
*Note that this is the “colloquial” terminology that is actually not strictly true. It’s actually solely a function of vapor pressure. But for the purposes of calculating humidity, this doesn’t actually matter. See
this page, which is also the source for the numbers used above.)
