Author Topic: The great capacitor shoot-out- more stupidity at 3 sigma  (Read 9152 times)
Offline subolg123
Offline theatrus
Re: The great capacitor shoot-out- more stupidity at 3 sigma
« Reply #1 on: April 11, 2014, 11:51:17 pm »
aural memory
that's really all you need to know about this article.
Software by day, hardware by night; blueAcro.com
Offline nanofrog
« Reply #2 on: April 12, 2014, 01:20:50 am »
aural memory
Exactly.
I interpret this as there's enough suckers people that there's a business opportunity for the right person that can come up with the right BS marketing material and pretty packaging.  ;)  :P
Offline TMM
« Reply #3 on: April 12, 2014, 03:06:52 pm »
While some caps had their outer foil clearly marked (VCap, Hovland, and so on), the RelCaps (among others) were sometimes a problem. When we bought RelCaps from Michael Percy Audio, the outer foil was already marked by MPA. Otherwise, we used an oscilloscope to locate it ourselves. To do this, we attached the hot and ground wires of the scope's probe to each lead of a given cap and placed the cap perpendicular to an active AC line, such as the power cord of the scope, itself. We observed the noise pattern on the scope, reversed the leads, and determined that the correct orientation was the one in which the scope's pattern display was the shortest in height. That is to say, when the display was the shortest, the scope's probe ground connection was considered to be connected to the outer foil of the cap.
:palm:
Offline Tac Eht Xilef
« Reply #4 on: April 13, 2014, 04:02:09 am »
:palm:
Notice they say "... the scope's probe ground connection was considered to be connected to the outer foil of the cap". This is their out. All they're really saying is that they had a method or process for making a decision, and stuck to it. They're not actually saying say it's the correct method, or a usable method, or even that it gives accurate /consistent / repeatable results - simply that they had a method, and the method itself was consistently applied.
It's both a blessing and a curse. On the one hand, it's a nice easy point for a later researcher to criticise - but, on the other hand, they then have to go through the whole process of proving the method is rubbish (and face the inevitable arguments with people who claim it isn't) before getting to present their own findings. And in the meantime there'll be plenty of other lazy studies which simply state something like "Our study used the method initially proposed by Bullshyte and Crapp, which was considered suitable for determining which lead is connected to the outer foil".
You might be surprised to learn how often that particular manipulative construct is used in scientific literature...
Offline BennyBoy
« Reply #5 on: April 13, 2014, 11:26:59 pm »
Really sick folks out there. Spending thousands on caps, when thousands of kids are starving.  :--  I blame the ignorant people for fuking without funds, but the poor kids should not have to pay with there lives, while A-holes argue over capacitors. :wtf:
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
Offline echen1024
  • 15 yo Future EE
« Reply #6 on: April 14, 2014, 02:19:57 am »
I need to start my own cap business...
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline sleemanj
  • Professional tightwad.
« Reply #7 on: April 14, 2014, 05:10:53 am »
As per usual for pseudoscience  audiophoolery, they didn't bother with that whole rigorous scientific method thing.
these were not "blind" tests
the panel was [em]generally[/em] unaware of which cap they were listening to
hose with the lowest expectations were installed first followed by those for which the expectations were the highest,
|O
It's not like it would have been hard for them to do it properly, put up a screen between test subject and test setup.  Properly randomise the tests. Play the same music pieces for each test.  And throw in a control of some bog standard cap.  That's it.  Nothing more complicated needed.
Offline EEVblog
« Reply #8 on: April 14, 2014, 05:35:15 am »
With capacitors being one of the largest variables, we needed a method to show how they performed in different circuits under "real world" listening conditions. Of course, despite our attempt at objective evaluation, in reality, these opinions are highly subjective and based solely on our own listening tests in our own projects.
That's all you need to know to brand this audiophoolery.
You either get quantitative measurements (with say an Audio Precision), or you don't.
You can likely make one sound better by smearing it with peanut butter - so what?
Offline John Coloccia
« Reply #9 on: April 14, 2014, 06:55:51 am »
:palm:
Meh...amateur hour.  For only $200, you can send me your capacitors and I will use my x-ray galvanometer to PROPERLY and PROFESSIONALLY determine the outer foil.  Then I will trim the leads of the capacitor to the optimal lengths....not necessarily the SAME length, btw.  Only a complete novice would do that.  They will be trimmed to take the differential capacipedance into account.  Finally, they will be cryostatically biased.  I feel this last step is critical to opening the sound stage and preserving the width and depth of the music, while at the same time dramatizing the length.
In case some have forgotten here is a run down of my qualifications and equipment.
https://www.eevblog.com/forum/chat/spotted-this-and-had-to-share/msg340855/#msg340855
Offline amyk
« Reply #10 on: April 14, 2014, 09:17:40 am »
By "aural memory" they're not referring to some weirdness of the caps themselves, just the listener's idea of remembering how the previous choice sounded.
And if you want to do the testing a little bit easier, connect up all the caps to random positions on a rotary switch. Ask the listener to turn the knob to the position that sounds best. Move caps to different positions on the switch, then repeat.
Offline zimzom
  • Country: ph
« Reply #11 on: April 14, 2014, 10:23:18 am »
I think it would be a great kick-starter project.
The angle that nobody seems to have explored is all these guys are worried about audio fidelity ect.. why not sell them hokum calibrated testing kits for the capacitors, resistors, valves, transformers ect. Have a little meter with "audio warmth", "aural memory checker" ect..
The thing is all these fellas that prey upon the excess cash and naivety of the customers will have to buy into the scam because it perpetuates the overall market. They cannot call you out for fear of bringing down the whole house of cards.
« Last Edit: April 14, 2014, 10:30:52 am by zimzom »
Offline AntiProtonBoy
    • Youtube Channel
« Reply #12 on: April 14, 2014, 01:47:24 pm »
One day, I'm going to make a troll site for audiofools, just for the lulz.  >:D
Offline NANDBlog
  • Current job: ATEX certified product design
« Reply #13 on: April 14, 2014, 01:53:26 pm »
That would be an overkill. Just pay some taiwan company for custom labels like:
"Omega One
Wolfram Teflon Triaxial
0.000001% THD 350V 125C"
Offline echen1024
  • 15 yo Future EE
« Reply #14 on: April 14, 2014, 04:19:28 pm »
"Omega One
Granted, I'm just gonna stick the cheapest caps I can find in Shenzhen electronics mart into a fancy looking wooden box, and then print off a crap cal certificate. Total cost to me? $20 at most. Sell it for $400.
Offline station240
« Reply #15 on: April 15, 2014, 03:00:09 am »
"Omega One
Bonus points if you find some of these at the markets and use them.
And yes in the original story, those caps were installed in an amplifier.
Offline EEVblog
« Reply #16 on: April 15, 2014, 03:09:15 am »
I'm waiting for an amp that has homeopathic levels of distortion.
Offline miguelvp
« Reply #17 on: April 15, 2014, 03:17:12 am »
The thing is, they all do. But with the right tune, not the right cap.
Offline BravoV
  • +++ ATH1
« Reply #18 on: April 15, 2014, 03:22:58 am »
Dave, ever consider to make a drive/walk through rant video dedicated on this audiophool matter ?  >:D
Hopefully it won't increase your daily death threads list.  :-DD
Offline TMM
« Reply #19 on: April 15, 2014, 04:23:22 am »
"Omega One
Nah, wouldn't work. Audiofools disregard quantifiable measurements like THD and instead rely on their 'golden ears'.
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #20 on: April 15, 2014, 01:26:58 pm »
Putting more amps in series to decrease THD?  :-DD
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline NANDBlog
« Reply #21 on: April 15, 2014, 05:14:47 pm »
Sadly that actually works. On opamp level.
Offline Mark Hennessy
    • My electronics and audio website
« Reply #22 on: April 15, 2014, 08:58:31 pm »
http://www.eevblog.com/2009/09/07/eevblog-29-audiophile-audiophoolery/
