Instead of buying your 74xxxxx chips, you can always ask me.
I'm again in a little 2 minute break at work, so no photos elas, but I have a cabinet that's been nearly untouched for many years now with a vast array of DIPs. :-) If you don't care about a '9* date code.
To be honest, I'm not going to go through the hassle of packing and shipping them, so it's moot as an offer, but to make the point the other way... I have the stock but no desire to ever use them again.
I'm a ... probbyist ...? (pro-hobbyist) I do still make many PCBs myself, and solder them myself, often without the use of paste. Not because I don't want to, but because it's more of a craft left over from the very early '90s where I had only the reel of klunky 1mm tin/lead wire (with flux, luckily), a jar of smelly resin and some alcohol to thin that for application.
But packages like these aren't that big a problem for me, to be fair I have added SMD-pre-heaters and SMD-rework guns to my collection and have put in several days of destructive fooling around with them to tune my craft so to speak.
But, yes, I do try to avoid them in any fully hand-made design, since the PCB tolerances and manual placement tolerances do add up and the risks become quite large.
By the way, "a bit too little paste" isn't as dangerous as you put it, since there's always some electrically insulating matter between the top copper and whatever thing is beneath that and the vias needed to transport that heat away aren't going to win from a thin layer of paste which may only cover 70% of the possible connection.
Usually those pad sizes are over dimensioned for the transport required or attainable on the current technologies in matters of PCB materials and processes.
Not for your hobby, but because industry also doesn't really like things that come down to the single percent.
If I ask a fab to place something (whether chip or paste) with an infinitesimal accuracy they will sometimes agree, but you should see the bill they send at the end, nobody would use the chip if a fab placing it had to send a bill that has a +fee for that one chip that's the same as the chip cost (or double that).
All that said, I do agree with the general consensus that no hobbyist should want to use a chip like this. I don't want to either, I just do sometimes, because.... eh... reasons. (staying up to date with developments and tech mostly)
