Author Topic: The Nutter Pulls Apart Dental Xray  (Read 5830 times)
Offline SionynTopic starter
« on: November 01, 2012, 04:44:34 pm »
cool yes but rather dangerous hence nutter who bottles pcb oil ?
eecs guy
Offline Mediarocker
  • If it ain't broke, open it anyway!
Re: The Nutter Pulls Apart Dental Xray
« Reply #1 on: November 01, 2012, 05:18:45 pm »
I definitely hope he's wearing some form of radiation protection.... I don't care how well that leaded shield protects..
Offline M. András
  • Country: hu
« Reply #2 on: November 01, 2012, 06:01:00 pm »
wow that geiger counter was almost at maximum
Offline G7PSK
  • It is hot until proved not.
« Reply #3 on: November 01, 2012, 06:24:31 pm »
He was as safe as the dentist that used it originally. He did not put himself in the X ray beam at any time.
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #4 on: November 01, 2012, 08:58:38 pm »
Messing with this stuff, I think some people should be locked up for their own safety sake, let alone ours.
no one would or will tell me how to delete this account
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #5 on: November 02, 2012, 09:11:06 am »
So uhh whats the big deal? The only hazard there MIGHT be is that the oil might be PCB.
But an X-ray machine does not contain anything radioactive. It does not emit X-rays unless you like... power it on (see http://en.wikipedia.org/wiki/X-ray_tube ).
So unless the oil was PCB I don't see anything "nutty" in the video.
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline firewalker
  • Country: gr
« Reply #6 on: November 02, 2012, 09:32:49 am »
The oil should be vegetable (Canola, Soya) oil as it is equipment constantly around people.
Alexander.
Offline amyk
« Reply #7 on: November 02, 2012, 01:38:44 pm »
Interesting. I thought Xray tubes needed DC to operate, but didn't see a rectifier anywhere inside the unit.
Looks like has a competitor. :)
« Reply #8 on: November 02, 2012, 02:57:12 pm »
They don't need DC to operate, as the tube ia actually a diode, which just so happens to have a load built into it at the anode. It is quite happy with AC applied to it.
Same with a microwave magnetron, the capacitor and diode is just there so that the transformer can be cheap, as it does not then need to be wound for 2kV isolation on the coil and the former, which would make it more than double the size and also require it to have a big core gap to handle the saturation, or it will need a big ferrite bias magnet to keep it in the linear core region.
This one is oil cooled and has a very low duty cycle so the heat dissipation is not an issue for it, they just went for massive overkill as it worked out cheaper on a low production run unit. These tubes generally are run for under 100 hours total at 4-6 seconds at a time, not like a microwave where it will do thousands of hours at full power
Offline Mediarocker
« Reply #9 on: November 02, 2012, 07:27:14 pm »
Well given that this guy appears to open and test a lot of xray heads, I would expect him to at least take precautions to minimize his exposure. Of course he wasn't in the direct path of the beam, however with that open end of the shield I'd expect some leakage.. possibly negligible...
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #10 on: November 03, 2012, 12:24:26 am »
I feel sorry for the guys chisels.  :(
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #11 on: November 03, 2012, 12:50:40 am »
More so, as the dentist would have used it far more frequently.
Day Job: Mostly LEDs
Online Zero999
  • 0999
« Reply #12 on: November 03, 2012, 01:02:27 pm »
He also ran it at a much lower voltage than the rated voltage (otherwise it would've arced over) so the X-ray output was less energetic.
Offline Excavatoree
« Reply #13 on: November 03, 2012, 03:24:26 pm »
Obviously he's never heard of a cold chisel.   Shop teachers* everywhere cringe in horror.
*-sorry, I mean Industrial Arts Instructors
Offline chickenHeadKnob
« Reply #14 on: November 04, 2012, 10:00:38 am »
Yes! I thought I was the only one who noticed!   :-*      hammering plastic handles ... tsk ..tsk  safety violation! who do I report?
« Reply #15 on: November 04, 2012, 10:17:45 am »
Cheap chineeeeeese chisel sets are only good as that. I see builders that treat all tools as one of 2 things, either a hammer, or a cold chisel.
Will admit though that when using screwnails into concrete I will drill the hole and drive the screwnail in using the same SDS bit on the drill.
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
« Reply #16 on: November 06, 2012, 01:51:28 pm »
glasslinger (aka Ron Soyland) has a great YT channel. That bloke has kick arse glass working skills. Love his vacuum tube tutorials.
