If you like this sort of thing, then consider a string wrapped around the earth's equator (assuming the earth as a perfect sphere) and tied off at the ends. Now raise the string above the surface by some small amount all the way around, say 1 meter. How much longer is the string when raised and tied at the ends? Do same for the Moon, Sun, Jupiter, the solar system and the entire universe assuming all are spheres. Then redo for a beachball, basketball, baseball, pingpong ball, solder ball and an atom (assume all are spheres). Now compare the results, amazing indeed
If you like mathematics in electronics, look into analog filters and how the transfer functions of Butterworth, Bessel, Cauer, Chebyshev, Gauss, & Legendre interact in the frequency and time domains. Fun stuff indeed for those interested
Best,
Edit: Signal processing, both analog and digital, is another fascinating mathematical area
