Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Chat
Solid aluminium capacitor - replacement
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Solid aluminium capacitor - replacement (Read 291 times)
HendoNZ
Contributor
Country:
on:
January 09, 2021, 03:54:12 am »
Hi all,
I'm re-caping an old reel to reel (1970s) and I've come across a 3.3uf 25v cap. In the documentation its listed as a solid aluminium capacitor. Is there a modem day equivalent to this type, or can it be replaced with a normal cap?
Cheers
Logged
bob91343
Super Contributor
Country:
Re: Solid aluminium capacitor - replacement
Reply #1 on:
January 09, 2021, 06:35:17 am »
Any capacitor with similar ratings will probably be fine. Try it and see.
Logged
Ian.M
Super Contributor
Reply #2 on:
January 09, 2021, 09:12:20 am »
Wikipedia has 1983 as the date the earliest commercially available solid Aluminum electrolytic capacitors became available:
https://en.wikipedia.org/wiki/Polymer_capacitor#History
Are you sure the equipment is 1970s?
If it is a solid Aluminum electrolytic, and its capacitance is in tolerance, and its its ESR and leakage current still low, I'd simply put it back. Otherwise if you can't find a physically compatible modern equivalent, replacement with a solid Tantalum capacitor with at least 50% higher voltage rating should be acceptable. However we'd need to see that section of the circuit from the schematic (with supply rail voltages marked) to be certain, as Tantalum caps are extremely intolerant of high current transients and reverse voltage and have a nasty tendency to catch fire when subjected to either and connected across low impedance supply rails.
Last Edit: January 09, 2021, 09:17:19 am by Ian.M
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
General Chat
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Library
