Author Topic: Question charger universal battery movel  (Read 1589 times)
Offline micksmelanieTopic starter
« on: July 01, 2020, 10:48:26 am »
I bought this universal lithium battery charger for mobile devices but this charger only has two contact pins to charge and the BP-5L and smartphone battery has 3 contacts, how to use?
Offline jpanhalt
Re: Question charger universal battery movel
« Reply #1 on: July 01, 2020, 11:06:20 am »
Are you sure the third contact is needed for charging outside the device?  I believe it is usually some temperature sensor (thermistor)  or other protective connection.
« Reply #2 on: July 01, 2020, 11:25:21 am »
I don't know, I bought the charger but I still didn't receive the product
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #3 on: July 01, 2020, 11:43:39 am »
Have a look at this video, if you can tolerate the superfluousness of most of it !!!   :P
Basically, the centre is a sense point for the phone, that the 'charger' doesn't need...  :-+
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
« Reply #4 on: July 02, 2020, 10:23:16 am »
Does this charger charge batteries that use flat cable?
Offline steve30
    • Stephen Coates' Homepage
« Reply #5 on: July 02, 2020, 01:42:05 pm »
No.
Offline Ysjoelfir
« Reply #6 on: July 02, 2020, 01:44:50 pm »
No.
Don't lie, Steve! He could always extend the flat cables to contact those pogo pins. But... why would you? This charging could very quickly turn into a charing situation!
Greetings, Kai \ Ysjoelfir
« Reply #7 on: July 02, 2020, 03:14:02 pm »
Which accessory on Aliexpress do I have to buy to charge the flat battery battery using this charger? help me
he says to be universal but it is not
Offline tooki
« Reply #8 on: July 02, 2020, 03:45:48 pm »
I think you need to stop asking stupid questions. In every thread you’ve started so far, you ask something somewhat sensible, then as people engage, it becomes dumber and dumber to the point it’s obviously just trolling.
The following users thanked this post: Ysjoelfir, jpanhalt
Offline Ysjoelfir
« Reply #9 on: July 02, 2020, 08:54:34 pm »
A cable. preferably thick enough and rigid enough.
There is no such thing as "universal". Just remember:
We try to make all our devices more idiot proof, but they just keep inventing better idiots.
« Reply #10 on: July 03, 2020, 12:23:43 am »
in this charger I will not be able to charge lithium batteries with flat cable? I didn't find any accessories
Offline Ysjoelfir
« Reply #11 on: July 03, 2020, 06:30:54 am »
Your question was already answered.
Offline Benta
« Reply #12 on: July 03, 2020, 06:44:52 pm »
Sadly, EEVBlog does not support ignore lists.   |O
Offline tooki
« Reply #13 on: July 04, 2020, 12:06:09 pm »
Yep, even the "ignore" feature just hides the content of their posts, but not their threads, and not even the existence of the posts. :/
