Author Topic: fan noise versus speed  (Read 897 times)
Offline Rerouter
Re: fan noise versus speed
« Reply #25 on: September 09, 2019, 10:22:15 am »
You can define a limit, at what duty cycle does the cost savings reverse, that would be a solid counter argument followup I would think. e.g. at 0.1% bang-bang, how does it compare when you look at similar energy consumption vs the equivalent PWM, If you really wanted to stick the point you could even graph the net gain in airflow vs power consumption with duty cycle control vs bang-bang, as that spin up energy is lost every time in bang-bang
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #26 on: September 09, 2019, 11:26:54 am »
Yea, a brushless speed controllable fan is already cheaper in volume than a brushed one when you consider the per hour cost (40'000 hours versus 10'000) so the controller costs under £100, so any speed regulation will save money but yes your idea is good I may do that.
