Was looking through some old files, and found these oldies, a reminder of the first PCB set I made. Done with home etched boards, and toner transfer, using an electric clothes iron to do the transfer from the overhead transparency sheet to the PCB material. Still got the PCB drill I used, along with the loads of tiny fragile drill bits that you used to make the holes, and hoping you would not break all those fragile drill bits before you ran out of bits, with holes still left to do.
Pre CAD, and I did the originals on graph paper, reversed so the lines were faintly visible, but would not copy through, and then with some permanent marker pens to do corrections.
