Author Topic: There's fake caps and then there's not even trying.  (Read 2865 times)
Offline PsiTopic starter
« on: January 03, 2015, 09:26:57 am »
Rubycon caps, something tells me they are fake.  :-DD
Offline LoyalServant
Re: There's fake caps and then there's not even trying.
« Reply #1 on: January 03, 2015, 09:29:57 am »
Wow.  :wtf:
Are you going to pull them off and measure them?
« Reply #2 on: January 03, 2015, 10:37:39 am »
About the only thing on them that is somewhere near correct is probably the polarisation stripe, though it ciuld be to mark negative or positive lead..........
« Reply #3 on: January 03, 2015, 11:34:37 am »
The polarity strip is the same printing, so it rubs off too :P
The product is a RC speed controller which comes encased in clear heat-shrink, so normally you wouldn't be able to touch the caps.
I'm not sure if they never got a the final manufacturing step (baked on / clear coated) or if the factory worker loaded the printing machine with something other than ink.
« Reply #4 on: January 03, 2015, 11:44:21 am »
Pobably used a bottle of off brand cheap ink. Why waste good money on marking the fakes with permanent ink if they are going after the maximum profit per device.
Plus if they need another value or brand and have some left over just wipe clean and run through the marker again.
Offline Stonent
« Reply #5 on: January 04, 2015, 01:22:59 am »
My AliExpress $13.00 Samsung 64GB MicroSD card did that as well.
Offline amyk
« Reply #6 on: January 04, 2015, 03:08:52 pm »
Could it be some solvent from the heat-shrink (evaporating during heating) that degraded the ink?
