Author Topic: Apollo 16 launch from T-20 with James Burke 1972  (Read 1368 times)
Offline Homer J SimpsonTopic starter
« on: August 21, 2017, 05:47:31 pm »
The following users thanked this post: G0HZU, Tomorokoshi
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
Re: Apollo 16 launch from T-20 with James Burke 1972
« Reply #1 on: August 22, 2017, 10:27:27 am »
For some reason every link you post is invisible in my browser. Are you posting it differently than others? I'd like to view it!
Added..even using the drag over the invisible text does not show it.
Voltage does not flow, nor does voltage go.
Offline Tomorokoshi
« Reply #2 on: August 22, 2017, 12:33:29 pm »
For me, the links show up as a YouTube video directly embedded in the message. Do you get the same problem with all browsers? Which one do you use? Any blocking software?
When composing the reply the video still does not show up, but the link does:
://www.youtube.com/watch?v=g8jkjNdeEl8
Just add "http".
*Edit: removed "http" from link to prevent previewing.
« Last Edit: August 22, 2017, 12:35:26 pm by Tomorokoshi »
  • Country: pt
« Reply #3 on: August 22, 2017, 10:52:41 pm »
Bizarre at the least.. I use Mozilla and it works for everyone but his links.
I tried your "quote the message" dealio, and viola! :clap: I can see the link....
I only use Mozilla based non-spy browsers. And no need for blockers.
Well at least part of the problem is solved, thanks.
  • Country: pt
« Reply #4 on: August 22, 2017, 11:12:26 pm »
Regarding the audio.. "I said peak limiter not peak clipper!" |O
