Author Topic: This is messing with my head, Faraday Paradox !  (Read 903 times)
Online BrianHGTopic starter
« on: February 29, 2024, 07:36:55 pm »
 :scared:  Why?  The fact that I am seeing DC voltage doesn't make things any better.
See video:
« Last Edit: February 29, 2024, 07:38:58 pm by BrianHG »
Offline RoGeorge
Re: This is messing with my head, Faraday Paradox !
« Reply #1 on: February 29, 2024, 08:35:59 pm »
The next one shows mechanical rotation instead of DC volts:
Arago's Scheibe,Disk (also see the YT video description)
xofunkox-scientific experiments
And if that was not confusing enough, see the Sagnac effect.  Or look at the humble gyroscope hanged from only one side while it is defying gravity.  Physics is all smoke and mirrors.  This Universe is playing tricks on us, and I know it does, yet I can't evade it.  ;D
The following users thanked this post: BrianHG
« Reply #2 on: February 29, 2024, 09:27:18 pm »
Nothing confusing about those for me.  I can easily image the forces going on in my head...
 :scared: But that stupid magnet sitting on the wheel, not relatively moving, and it is still making DC even through the commutators shorted to 2 points on the disc...  |O
« Last Edit: February 29, 2024, 09:32:39 pm by BrianHG »
Offline ejeffrey
« Reply #3 on: February 29, 2024, 09:32:57 pm »
Despite starting off with "it's still not understood to this day" it provides a pretty clear explanation in the second half of the video.  You have to consider the effect of the leads.
Providing the explanation two ways, once where the magnetic field is though to co-rotate with the magnet and the other without makes it more confusing that it needs to be, but if you pick one it's fine.  The choice is rather meaningless anyway.
Offline ejeffrey
« Reply #4 on: February 29, 2024, 09:39:31 pm »
Also note that the bottom electrode goes to the axle, not the edge of the disc.
If you rotate the bottom electrode so that it passes under the top electrode, then shrink the magnet to only cover the area between the electodes it should be pretty clear what is happening.  The magnetic field in the rest of the disk is then irrelevant.
Offline RoGeorge
« Reply #5 on: February 29, 2024, 09:42:08 pm »
How about the Dzghanibekov effect?  No magnets and no wires, yet the the rotating object flips exactly 180 degrees back and forth.  That's not even smoke and wires, that's witchcraft.  :o
The Bizarre Behavior of Rotating Bodies
Veritasium
 :scared:
The following users thanked this post: BrianHG, mawyatt
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: February 29, 2024, 10:14:25 pm »
A classic:
The original site has unfortunately gone offline, but it is archived here:
https://web.archive.org/web/20190409110824fw_/https://mysite.du.edu/~jcalvert/tech/faraday.htm
This is just one teaser of course, but the bulk of the related pages should introduce or indeed teach the solution to it; I found these pages quite readable and informative, even their use of equations easy to understand.
Seven Transistor Labs, LLC
Offline RoGeorge
« Reply #7 on: February 29, 2024, 11:15:12 pm »
A few more circular motion oddities:
The Most Mind-Blowing Aspect of Circular Motion (see it in slow motion at minute 11:10)
All Things Physics
Coriolis Effect (see it in slow motion at minute 00:50)
TSG Physics
8.01x - Lect 24 - Rolling Motion, Gyroscopes, VERY NON-INTUITIVE (see both demos, at minute 22:18 ???, and 35:15 :o)
Lectures by Walter Lewin. They will make you ♥ Physics.
The only reasonable explanation to all these is that the circular motion was one of those unbaked features, released without proper testing.  Later, all the reported bugs of physics were proclaimed features, and never to be fixed, so to not break the backwards compatibility for the time travelers.  ;D
Offline rfeecs
« Reply #8 on: February 29, 2024, 11:22:23 pm »
From here: https://www.feynmanlectures.caltech.edu/II_13.html
There is no way to make sense, in general, out of the idea of “the speed of a moving field line.” The fields are our way of describing what goes on at a point in space. In particular, E and B tell us about the forces that will act on a moving particle. The question “What is the force on a charge from a moving magnetic field?” doesn’t mean anything precise.
So forget saying "the magnetic field is moving".
In both cases, whether the magnet is rotating or not, the magnetic field at each point (x,y,z) in space is the same.
So all that matters is the free charge that is moving through the field.
He pretty much said this at the end of the video.
Offline RoGeorge
« Reply #9 on: March 01, 2024, 12:43:26 am »
That reminds me of a guy from India, teaching in a very intuitive way the Maxwell's equations as if he was at the Feynman lectures about electromagnetism, and asking Feynman directly.  :)
Maxwell's equations are intuitive! (Ep: 1 - Power of Gauss's Law)
FloatHeadPhysics
Maxwell's equation explained logically! (Ep 2: Faraday's law powers the world)
FloatHeadPhysics
« Last Edit: March 01, 2024, 12:53:21 am by RoGeorge »
Offline EPAIII
« Reply #10 on: March 01, 2024, 03:01:30 am »
I watched that first video because, in spite of a degree in physics, I had never heard of the "Faraday Paradox". That's 9:20 that I will never get back.
It is only a paradox if you don't understand that you must consider the entire circuit and not just focus on one part of it. It is CLICK BAIT! Nothing more. No serious physicist would waste any time on it.
It is in the same league as those math problems that "everybody gets wrong".
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Online Circlotron
« Reply #11 on: March 01, 2024, 04:19:44 am »
I did a *lot* of thinking about this back in 2002. I came up with a flow chart that seems to lead to some awkward conclusions. If there are some wrong conclusions in it I'd like to know.
« Reply #12 on: March 01, 2024, 04:24:40 am »
LOL, nice logic puzzle.
Looking at the 'Arago's Scheibe Disk' helps: ASD
Offline EPAIII
« Reply #13 on: March 03, 2024, 08:00:52 am »
Without seeing the exact apparatus that you are talking about it is difficult to say anything.
Paul A.  -   SE Texas
