Ok I had to know what was inside, so I got one.
This one is a bit different and was a bit disappointed it wasn't the ST Micro ARM chip.
There's a QFP on the back marked:
TOSHIBA
T5DB0
1248 HUL
167288
JAPAN
On the other side there's a Micron chip labeled:
2VD12
NW322
And on the edge says QQVNB (Edit, found it:
http://www.micron.com/parts/nand-flash/serial-nand/mt29f1g01aaaddh4-it )
1Gb Serial NAND Flash
The other chip I can't tell a vendor, appears to be a BGA labeled
F3796 017
1244PM404
MALAYSIA
There's a small 5 pin chip right about 1/2 way between them, it appears to be labeled "PHP" or "PNP" I can't tell
And there's a small cluster of parts below the button marked "Down"
Two of them are 8 pin chips that even I can't read with my 20/10 vision, so I'll have to hunt down a magnifying glass later.
The battery pack looks identical to the pictures posted earlier so I didn't bother with it.
The LCD has a chip on the flex cable. I'd say around 16 or 15 mm long and 2 mm wide.
The end of the flex cable is a little wider than the chip and looks like it could go into a LIF ribbon connector but they've stuck another adapter on top of it to squeeze it down to about 6 or 7 mm wide and appears to have 24 pins.
Anyone have some data on the Toshiba chip or the one without the vendor name? I'm not having much luck.
