Author Topic: This picture is confusing on so many levels [FAIL]  (Read 2222 times)
Offline b_forceTopic starter
    • One World Concepts
« on: August 17, 2020, 02:44:10 pm »
I was looking for a funny pictures topic, but I couldn't find any (if there is one ,feel free to move this post)
I was just browsing the known websites for vacancies and all of a sudden I bumped into this picture.
Was actually part of website of a serious company.
Like, how, why and what?  ;) ;D :-DD :-DD :-DD
Feel free to share your own funny pics as well!!!
« Last Edit: August 17, 2020, 03:13:42 pm by b_force »
The following users thanked this post: Dr. Frank, bd139
Offline Chris42
Re: This picture is confusing on so many levels [FAIL]
« Reply #1 on: August 17, 2020, 02:59:24 pm »
Don't worry!
They know what they are doing.
It's quite clear that people working there know dark magic that allows them to see the electricity flowing through the circuits without any equipment.
But a bunch of people staring at the bench with some dark art stuff around them would look bad on a photo so they had to go to the  local
hardware store and buy some random equipment that regular mortals have to use. They didn't know how to connect it (and couldn't be bothered checking because of all important magic they had to do) so they just
plugged something, somewhere just for the photo.
I'm sure everything is fine. You just have to be a wizard to fit into their corporate culture.  :D
« Last Edit: August 17, 2020, 03:06:44 pm by Chris42 »
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: August 17, 2020, 03:07:29 pm »
one scope probe, one multimeter probe, ground clip on the headstack arm .. and the covers off. that'll work .. ( it could if there is a groudn strap between scope and multimeter ) but you can kiss the data goodbye ..
Offline Chris42
« Reply #3 on: August 17, 2020, 03:11:48 pm »
Gotta measure that waveform of voltage between casing and arm stack on a drive that isn't plugged in.
Online Ian.M
« Reply #4 on: August 17, 2020, 03:29:22 pm »
https://www.eevblog.com/forum/chat/stock-electronic-image-fails/
Reply #11 (above) is particularly memorable!
« Last Edit: August 17, 2020, 03:33:39 pm by Ian.M »
The following users thanked this post: b_force
« Reply #5 on: August 17, 2020, 03:52:15 pm »
Thanks, I will post it there!
(or can the admins do some magic?)
Online magic
« Reply #6 on: August 17, 2020, 07:57:41 pm »
Damn, about the only way they could make it worse is by pretending that the 3.5" disk came from the laptop.
And those nitrile gloves... who even comes up with those ideas? :scared:
Offline eti
  • MOD: a.k.a Unlokia, glossywhite, iamwhoiam etc
« Reply #7 on: August 17, 2020, 10:34:24 pm »
I like to give the benefit of the doubt. Although improbable, maybe they're measuring the level of static buildup on the head arm, with relation to ground, in a HDD design lab. Things spinning at great speed are known to generate static.
@b_force: to quote your sig back to you, consider this as a possibility: ""If you can't explain it simply (or at all), you don't understand it well enough." A. Einstein
Offline eti
« Reply #8 on: August 17, 2020, 10:36:55 pm »
I see no evidence of that being implied; the laptop being in the shot != the photographer implying that.  ;D
Online Ian.M
« Reply #9 on: August 17, 2020, 11:05:19 pm »
What about the poor gratuitous ConpactFlash card in the foreground? What did it ever do to be associated with such TechnoFAIL?
Offline bsfeechannel
« Reply #10 on: August 17, 2020, 11:13:10 pm »
shango066.
Offline Cyberdragon
« Reply #11 on: August 18, 2020, 05:50:20 pm »
Rossmann uses nitrile gloves as well. Customer computers are NASTY.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Online MK14
« Reply #12 on: August 18, 2020, 06:01:21 pm »
Here you go.
Offline CChin254
« Reply #13 on: August 18, 2020, 07:50:30 pm »
They could be checking for resistance/connectivity though...
Online coppercone2
« Reply #14 on: August 19, 2020, 01:42:36 am »
well the female one is the first instance I have seen where someone photographed a terminatrix model. Looks like she is resistance welding a control circuit for her fusion cannon.
« Last Edit: August 19, 2020, 01:45:45 am by coppercone2 »
Offline Red Squirrel
« Reply #15 on: August 19, 2020, 04:02:52 am »
Maybe they are measuring the actual data!  There might be a small voltage difference and they can tell how full the drive is.  :-DD
I like the fact that the probes are not plugged in, and the DMM is off.
Online coppercone2
« Reply #16 on: August 19, 2020, 04:35:53 am »
I thought they were trying to measure chassis resistance?
Offline janoc
« Reply #17 on: August 19, 2020, 09:35:29 am »
That - and also the sticky flux he is using. That stuff will get all over your fingers very quickly.
Online Halcyon
  • Global Moderator
« Reply #18 on: August 19, 2020, 11:44:24 am »
Feel free to post it in the existing thread. I'll lock this one.
