General => General Technical Chat => Topic started by: knotlogic on May 24, 2019, 02:29:47 am
For anyone who's done a Digi-Key order before... A lot of my items come in those resealable blue bags. Anyone know what they're made of and where I might be able to buy them from? I find I reuse them quite a lot, and they don't seem to tear as easily as some of the other small resealable bags I've used.
I reuse them also. I just looked and Digi-Key doesn't seem to sell them, although they do sell the anti-static conductive bags.
It might work to suggest they sell them as a Digi-Key part. I've also gotten the pink ones for some parts.
They're just anti-static polyethylene bags. Available from a number of suppliers, but generally not recommended for reuse, as apparently the dissipative treatment is not very durable. Conductive bags are recommended for anything truly sensitive.
https://www.uline.com/BL_7852/Uline-Anti-Static-Reclosable-Bags?keywords=ESD+bags (https://www.uline.com/BL_7852/Uline-Anti-Static-Reclosable-Bags?keywords=ESD+bags)
https://www.all-spec.com/Catalog/Static-Control/ESD-Safe-Bags/Anti-Static-Polyethylene-Bags? (https://www.all-spec.com/Catalog/Static-Control/ESD-Safe-Bags/Anti-Static-Polyethylene-Bags?)
https://www.mcmaster.com/static-control-bags (https://www.mcmaster.com/static-control-bags)
These?
https://www.digikey.com/product-detail/en/desco/13881/16-1432-ND/405665 (https://www.digikey.com/product-detail/en/desco/13881/16-1432-ND/405665)
Yes that's true, but from memory Digikey don't put very sensitive parts in those bags, unless they're already in something more conductive, such as carbon loaded foam. They're anti-static because they will likely be used around static sensitive components.
I don't see the problem with reusing them for non-static sensitive parts.
The blue bags (classically pink, as I recall) are only designed to prevent charge build, as opposed to protecting their contents like a shielded bag.
It couldn't hurt to ask Digikey if they'll name their supplier. Sometimes the bags are marked, I don't recall if any of my Digikey ones are.
Yes typically Digikey sends ICs in double bags, with the blue one inside a regular antistatic bag. They only send non-sensitive components like passives in just a blue bag alone.
Digikey ships MSL components double bagged.
These?
That's it! somehow I filtered those out as I searched down.
Would be cheaper to order a whole bunch of cheap parts then buying the bags.
These?
22 US cents a piece???
I swear those bags are a menace, I need to get my ESD safe micro parts drawers made with little lids and make a bunch of jigs and stuff so I can make more.
I consolidate when I can and once in a while throw out a gigantic stack of them , I think I had a box that was like 2x3 feet loaded with fucking digikey bags.
listening to god damn crinkle crinkle every time you wanna get a part |O
