I am not sure about this particular part, but authorized distributors usually follow the manufacturers' recommendations to the dot as they do not want to be held responsible for a mess up in an end customer product.
And yes, "plastic" and metal can be hygroscopic - i.e. loooooove to
adsorb and maybe even
absorb water in the air.
However, if this is a small hand-soldered batch then you should be fine - in massive production runs you want to keep moisture away to refrain from interfering with the oven soldering process.
Just to play safe, only open the package before soldering the part, and keep the remaining ones in the tightly closed bag with the silica-gel and the moisture card (usually there is one).
