Guessing you aren't protecting against IEC 61000-4-5 surge, on a DC bus. More pedestrian surges may be more likely: ESD, perhaps automotive surge (fast, positive and negative pulses), perhaps hot plugging/inrush (an LC resonant peak waveform). Or just overvoltage in general, say from using the wrong power supply.
In that case, you won't see the peak clamping voltage -- it is measured at a peak current much higher than these cases will see. The clamping voltage will be somewhere between breakdown and that. Exactly where, is hard to say without a plot, and without knowing the expected peak current.
Absolute maximum ratings are the highest point of survival, with survival not guaranteed beyond there. The failure mode could be gradual breakdown due to a stress condition, or it could be acute. The real breakdown voltage is some fraction higher than the abs. max., typically 10-30% (in the same way that the TVS's breakdown is somewhat above its nominal rating, for the same reason!), though of course you don't know which end of that range a particular part will fall in.
Breakdown may be absolute (the tiniest current causes failure), or it may be robust (able to withstand significant avalanche current, until it fails thermally). The avalanche characteristic can be anything from positive to negative resistance; a robust avalanche breakdown will have some modest resistance, and a positive tempco (so the breakdown voltage rises as it heats up; avalanche devices of matched voltages will share current). Avalanche can have negative resistance and even weird snappy discharge behavior (an avalanche pulse discharge circuit is a preferred way to generate relatively large, quite fast (sub 1ns!) edges; even an ordinary 2N3904 can exhibit this phenomenon), though I would not expect an IC to exhibit this behavior.
You'd have to ask the manufacturer about this, or measure a range of parts yourself. Note, the manufacturer may not be interested in telling you about any of this, instead taking the safer route of simply saying: don't do, that, use this nominal supply voltage with this TVS, nevermind if it's lower than your required 30V operating range.
Which brings me to the final point: the safest design is not to worry about any of this. Shop for a 60V or higher part instead. Then you will have more than enough headroom to choose a TVS of adequate rating.
Personally, I wouldn't have a problem with using the 42V part, with a SMAJ30A, for purposes of inrush and ESD. For lightning induced surge, or automotive load dump, I would look for another solution, perhaps the higher voltage rating, perhaps a LDO to afford ride-through, or a switch to disable or crowbar the input when such voltages are applied. (There are load dump protection devices which do exactly this.)
