Hi all,
I may be being silly here so bare with me... I am designing a circuit which will drive some IR emitters from a dsPIC. The PIC runs off +3.3V and the diodes require 100mA each. I intend to use a ULN2003A transistor array to drive the necessary current. Now at 100mA the diodes have a typical voltage drop of 1.4V (1.7V max). The transistor array has a Vce saturation of 0.9V (1.1V max). So if I add the total voltage drop I get 2.3V leaving 1V across the current limiting resistor, hence I require a 10R resistor. Is this correct?
Now the second question is that if I wanted to drive two IR emitters from a single I/O port could I just place them in parallel with a smaller limiting resistor?
Cheers,
Dave
