I suspect you'll find two terminals each for positive and negative. Earth will be via the chassis.Popping the board out and taking a look at the layout will identify them very quickly.
Quote from: Monkeh on January 25, 2014, 12:19:00 pmI suspect you'll find two terminals each for positive and negative. Earth will be via the chassis.Popping the board out and taking a look at the layout will identify them very quickly.On the similar, fixed voltage supplies i have, there is a dedicated earth terminal.
Pulling the boards will be the last resort if no one can help with a translation. It might be worth doing that anyway to check out the erthing.
First the small label (on the cardboard box) Model: wk648 Enter: AC220V Export: 0-48V (few characters that possibly mean "name"?): PWM DC Converter Power Supply Now the longer label, each little square separated by a "-" Potentiometer - Power Indicator - Export - Excitation - Enter AC220V
Export is output (probably) but Excitation?
Sorry about the quality of the image.
I am a native Chinese speaker. "Field coil" is the best I could come up with for the translation of the middle 2 terminals. I have seen similar units from China with terminals labelled "field" in English. Exactly how those terminals are used I have no idea as I'm not familiar with these devices.
