Author Topic: Transmission lines - a visual explanation  (Read 1863 times)
Offline android
« on: August 03, 2016, 11:12:27 am »
Eugene Khutoryansky provides another excellent (as usual) visual explanation for the mathematically challenged like me :)
http://youtu.be/ozeYaikI11g
Lecturer: "There is no language in which a double positive implies a negative."
Student:  "Yeah...right."
The following users thanked this post: Jeroen3
Online Kalvin
  • Embedded SW/HW.
Re: Transmission lines - a visual explanation
« Reply #1 on: August 03, 2016, 11:36:14 am »
The Dr. J.N. Shive's lecture also worth looking:
The following users thanked this post: RobertHolcombe, Electronoooob
Offline android
« Reply #2 on: August 03, 2016, 01:53:27 pm »
Thanks Kalvin,
It's refreshing to see a "vid" that is straight to the point without all the meandering that is characteristic of the youtube era. Good find. BTW, 1959 was an excellent year IMHO.
Offline whalphen
« Reply #3 on: August 03, 2016, 10:56:40 pm »
I especially enjoyed Dr. J.N. Shive's video.  Thanks for posting!
Online hamdi.tn
  • Country: tn
« Reply #4 on: August 04, 2016, 12:29:50 am »
wow ... i hope i can show this to my high school and university professor , just to let them know how useless they are. i did read hundreds of documents about waves and reflection ... i can totally say this one goes directly to the point and it summarize it. well this was not a wasted 30 minutes of my life  :-DD
Offline b_force
    • One World Concepts
« Reply #5 on: August 04, 2016, 11:01:04 am »
I think best for most people, is to translate everything to mechanics, because it is more visual.
This is called analogy between electronics and mechanics.
A capacitor behaves like a spring, the mass of a object is like an inductor and a damper works like a resistor.
https://en.wikibooks.org/wiki/Engineering_Acoustics/Electro-Mechanical_Analogies
But there are a million other resources to be found on the web.
The beauty of this is with control theory it doesn't matter if you're talking about train mechanics, an electrical circuit and even certain chemical processes.
It all has similar behavior with very similar formulas.
(and yes, professors have a tendency to make everything overly complicated, boring and even missing the whole point)
"If you can't explain it simply (or at all), you don't understand it well enough." A. Einstein
http://www.oneworldconcepts.com/ | http://www.soundprojects.com
