Author Topic: Transparent wood with comparable strength ... and DIY-able  (Read 1267 times)
Offline BravoVTopic starter
  • +++ ATH1
« on: February 10, 2021, 12:02:08 pm »
Looking at the chemicals involved and the processing which are not hard to find and also just UV light or Sun light.  :-
-> Solar-assisted fabrication of large-scale, patternable transparent wood
Its also downloadable in PDF.
« Last Edit: February 10, 2021, 12:06:27 pm by BravoV »
Offline westfw
Re: Transparent wood with comparable strength ... and DIY-able
« Reply #1 on: February 18, 2021, 02:17:09 am »
FWIW, I've been trying this, and have been unable to get a piece of balsa to bleach using the peroxide and sun I have available :-(   Maybe I need to wait till summer!
  • +++ ATH1
« Reply #2 on: February 18, 2021, 05:54:13 am »
Please, update us on your work, thanks.
Offline thm_w
  • Non-expert
« Reply #3 on: February 18, 2021, 09:47:37 pm »
You put sodium hydroxide and hydrogen peroxide yeah?
The lignin-modified wood was prepared by brushing 25 ml H2O2 and 5 ml NaOH solution and illuminating with UV light for 1 h.
Offline westfw
« Reply #4 on: February 19, 2021, 02:24:56 am »
I didn't see the NaOH the first time.
Also, I want to try a range of "consumer" peroxides:3% "medicinal."6-10% "hair bleach."~27% "pool sanitizer"
Offline westfw
« Reply #5 on: March 17, 2021, 02:15:43 am »
Someone else (amateur) has published first!   https://youtu.be/s9FdbYWK7rc
Pretty nicely done, if a bit "chatty."  (includes lots of failure!  Only "marginal" success in the end.)
The NaOH did turn out to be significant.
