Tektronix scopes and plug-ins used the 180 deg trim caps, single disc céramique are quite stable but the thin metalized ceramic rotors easily break after decades.
The modern multi layers plastic dielectric are often junk quality from China, thus the low number of rotation
99% of trim caps are set once and forget.
Finally the normal variable capacitors used in RX, TX and old radio use last forever
Jon
