Hi All,
I need to call on your combined expertise.
A Customer had a very nice toilet sign made up (with Black Acrylic, and a transparent cutout).
They wanted LED strips on the back of the sign.
Normally I use the LED Strips that have the built on double sided tape, but I put a streak of Sestic Cable Glue as well, because the tape on the back of those strips is not too sticky.
Now, I went and put a streak of this glue along the top part of the sign (the black acrylic), but I was distracted, or overtired from several nights overtime in a row, or whatever. And I did not realise that the sign was upside down.
What that means is that the customers nice new laser cut expensive sign has a streak of this Contact Adhesive glue along the front
, instead of the back.
Is there a way to remove this adhesive, without melting the acrylic, or using a blade to shave the acrylic off?
Thanks in advance for your insight.
